[Qgis-developer] QtCreator and QGis
Abhay
abhay.menon at gmail.com
Sun Apr 12 17:42:23 EDT 2009
2009/4/13 Lynx <lynx21.12.12 at gmail.com>
> On Sunday 12 April 2009 18:45:26 Abhay wrote:
> > Hi All,
> > Has anybody used qtCreator with qgis source code for development purpose.
> > If so could you please post the step to how to implement the same.
> > Thanks and Regds.
> > Abhay.
> Hi Abhay,
> I am using QtCreator with QGIS source for development purpose. I have set
> of *.pro files that contain the necessary lines to build QGIS on my machine.
> So i attached theirs and the script that put theirs in properly directories.
> To use it put the archive in QGIS directory and unzip, then change dir to
> prodir and run script ./pro_file_struct. After that you should correct some
> .pro files to build QGIS (if you have some packages in no standard path).
> Well, i hope it will be useful :)
> Qgis-developer mailing list
Hi Lynx,
Thank you for the input.. I shall try your solution and let you know.
Rgds.
Abhay.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090413/681154e5/attachment.html
