[Qgis-developer] QGIS 1.1 testing
Giovanni Manghi giovanni.manghi at gmail.com
Wed Apr 29 05:04:04 EDT 2009
I have built rev. 10654 on Jaunty 32 bit (with grass 6.4rc4) and I'm
experiencing none of the referred problems.
-- Giovanni --
On Tue, 2009-04-28 at 17:42 -0700, Alex Mandel wrote:
> These tests were done with Release 1 1 branch built on Ubuntu 8.10
> 32bit, installed into /home/user/apps/
> Attribute table actions buttons are all missing their logos.
> GRASS Plugin always starts off for some reason.
> GRASS opening the toolbox give a /grass/config/default.qgc not found.
> Hence module List etc are missing.
> (I'm guessing I missed something in the grass-plugin build)
> -Tried both libgdal1-dev 1.6.0-1 and libgdal1-dev 1.5.4-2
> -These are working fine in my repo pulled versions of qgis
> -tried with GRASS 6.3 and custom 6.4
> Spatialite works but fails to detect geometry type in all tests
> including the example database provided from spatialite's website.
> *.db is also a common extension for sqlite, works fine if all files is
> selected and a .db sqlite file is picked.
> Why is spatialite on the file menu instead of the database menu. It's
> not more or less of a database than the ESRI personal geodatabase(also a
> single file)?
> Just some notes as I work my way through, same issues with trunk.
> I think the grass stuff is a build error on my part, not sure how to
> correct and the spatialite stuff are just things to work on, but not
> holding me up at all.
> Thanks,
> Alex
> Qgis-developer mailing list
