[Qgis-developer] Primary Key detection enhancements: can it be
merged in the 1.1 release?
Andreas Neumann
a.neumann at carto.net
Thu Apr 30 02:00:49 EDT 2009
ok - sorry - I must have missed your previous answer.
It is understandable that you cannot merge in changes after the branching
took place.
And thanks for considering a 1.1.1 release soon!
Andreas
On Wed, April 29, 2009 1:22 am, Tim Sutton wrote:
> Hi
> On 28 Apr 2009, at 11:26 AM, Andreas Neumann wrote:
>> Hi,
>> Jürgen just provided a useful enhancement which speeds up project
>> loading
>> when complex Postgis Views/Tables are involved. It solved my issue
>> where a
>> project previously loaded in 3-4 minutes and after the enhancement it
>> loads in 10 seconds.
>> I would like to ask if this can still be merged into the 1.1
>> release, even
>> after the branch from the SVN trunk. This is very important. I am
>> not the
>> only one suffering from the bad performance when loading project files
>> with complex Postgis tables/views. At least 2-3 other persons also
>> reported that this is an issue for them.
>> I think this is worth investing the extra work required for
>> reviewing this
>> enhancement and merging this into the 1.1 official release.
>> See the thread starting at
>> http://lists.osgeo.org/pipermail/qgis-user/2009-April/005182.html
>> for more
>> information.
>> Thanks for your consideration and best wishes,
>> Andreas
> I answered this previously, but just to make sure you saw my reply I
> will repeat it here. Since the 1.1 release is already in packaging
> process and made its way into some repos, we will have to release this
> as 1.1.1 which we can set in motion as soon as I return from Brasil on
> the 4th of May.
> Until the 1.1 release is gone out the 1.1 branch should be frozen
> except for packaging related commits otherwise we will have confusion
> with some platforms having the fix and others not.
> Regards
> Tim
>> Andreas Neumann
>> http://www.carto.net/neumann/
>> http://www.svgopen.org/
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Andreas Neumann
