[Qgis-developer] ECW library location for OSGEO4W
Jeremy Palmer JPalmer at linz.govt.nz
Mon Aug 3 20:13:00 EDT 2009
Is there any reason why I have to copy the ECW libs (NCScnet.dll, NCSEcw.dll, NCSEcwC.dll, NCSUtil.dll) into the qgis app directory (%OSGEO4W_ROOT%"\apps\qgis\bin) to get ECW support? When I place the libs into the %OSGEO4W_ROOT%\bin directory, ECW support for gdal 1.5 and 1.6 works fine, but qgis does not register the format.
I'm getting the same results on QGIS version 1.02, 1.1 and1.2 (trunk), on an up to date installation of OSGeo4W. My OS is WinXP SP2.
Cheers
Jeremy
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090804/f95c670e/attachment.html
