[Qgis-developer] German QGIS Compiling Tutorial using OSGeo4W
Maxim Dubinin sim at gis-lab.info
Mon Aug 10 11:44:04 EDT 2009
Hi Florian,
here is English translation with few bugs fixed (note new cmake gui,
some links, paths to osgeo4w\qt etc.)
in general QGIS compiles and run well using this approach, but I could not
make Python support work.
it also would be nice to add explanations on adding debugging output.
thanks for your work.
Maxim
FH> I just want you to know that I created a german QGIS compiling tutorial
FH> using msvc and the osgeo4w package under windows xp (I didn't find a
FH> tutorial which uses osgeo4w).
FH> If anyone of you is interested you can find the pdf in the attachment. A
FH> HTML-Version will be released within the next days I hope.
FH> I hope that this is helpful to anyone.
FH> Thanks to Tim Sutton, David Willis und Jürgen Fischer for your tutorial,
FH> which I related to.
FH> Best regards,
FH> Florian
Type: application/msword
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090810/7676fe2a/qgis-compile-vse-0001.doc
