[Qgis-developer] Probably all busy,
but again: compiling troubles...
Tim Sutton
lists at linfiniti.com
Sat Aug 15 18:54:48 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
anibal alarcon wrote:
> Hi tim
> Now start compile, but at the end get another error:
> ccmake ..
> c
> g
> CMake Warning (dev) at CMakeLists.txt:79 (ADD_EXECUTABLE):
> Policy CMP0003 should be set before this line. Add code such as
> if(COMMAND cmake_policy)
> cmake_policy(SET CMP0003 NEW)
> endif(COMMAND cmake_policy)
> as early as possible but after the most recent call to
> cmake_minimum_required or cmake_policy(VERSION). This warning
> appears
> because target "timtut2" links to some libraries for which the linker
> must
> search:
> -lpthread, -ldl, -lpthread, -ldl
> and other libraries with known full path:
> /home/anibal/apps/lib/libqgis_core.so
> CMake is adding directories in the second list to the linker search
> path in
> case they are needed to find libraries from the first list (for
> backwards
> compatibility with CMake 2.4). Set policy CMP0003 to OLD or NEW to
> enable
> or disable this behavior explicitly. Run "cmake --help-policy
> CMP0003" for
> more information.
> This warning is for project developers. Use -Wno-dev to suppress it.
> If I try with cmake .. and after make:
> debialinmov:/home/anibal/dev/cst/2_basic_main_window/build# make
> [ 14%] Generating ui_mainwindowbase.h
> [ 28%] Generating moc_mainwindow.cxx
> [ 42%] Generating qrc_resources.cxx
> Scanning dependencies of target timtut2
> [ 57%] Building CXX object CMakeFiles/timtut2.dir/main.o
> [ 71%] Building CXX object CMakeFiles/timtut2.dir/mainwindow.o
> [ 85%] Building CXX object CMakeFiles/timtut2.dir/moc_mainwindow.o
> [100%] Building CXX object CMakeFiles/timtut2.dir/qrc_resources.o
> Linking CXX executable timtut2
> /home/anibal/apps/lib/libqgis_core.so: undefined reference to
> `QStandardItemModel::mimeTypes() const'
> `QPainter::drawImage(QPointF const&, QImage const&)'
> /home/anibal/apps/lib/libqgis_gui.so: undefined reference to
> `QPainter::fillRect(QRect const&, QColor const&)'
> `QFileDialog::setVisible(bool)'
> `QStandardItemModel::dropMimeData(QMimeData const*, Qt::DropAction, int,
> int, QModelIndex const&)'
> `QStandardItemModel::mimeData(QList<QModelIndex> const&) const'
> `QPainter::drawPixmap(QPointF const&, QPixmap const&)'
> `qFlagLocation(char const*)'
> collect2: ld returned 1 exit status
> make[2]: *** [timtut2] Error 1
> make[1]: *** [CMakeFiles/timtut2.dir/all] Error 2
> make: *** [all] Error 2
> Sorry, but I want to migrate my applications (mbx) on MapInfo and now I
> know where to start...
> :-) == QGIS
> Best regards
> Anibal
So it looks like your Qt4 install is not being found properly either.
Can you post :
- - the cmake settings you have for the various Qt libs
- - the ccmake command line + options you used when you initially ran ccmake
Thanks
Tim
8<--------------snip-------------
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkqHPLgACgkQqk07qZdiYjeRagCeOsUwV9QzM2ndXN47knoGr838
bRYAoKJbccoKUGX+rCieyZnF045yDV+y
=a9dW
-----END PGP SIGNATURE-----
