[Qgis-developer] Probably all busy, but again: compiling troubles...
anibal alarcon anibal.alarcon at gmail.com
Sat Aug 15 16:32:52 EDT 2009
Hi tim
Now start compile, but at the end get another error:
ccmake ..
c
g
 CMake Warning (dev) at CMakeLists.txt:79 (ADD_EXECUTABLE):
   Policy CMP0003 should be set before this line.  Add code such as
     if(COMMAND cmake_policy)
       cmake_policy(SET CMP0003 NEW)
     endif(COMMAND cmake_policy)
   as early as possible but after the most recent call to
   cmake_minimum_required or cmake_policy(VERSION).  This warning
appears
   because target "timtut2" links to some libraries for which the linker
must
   search:
     -lpthread, -ldl, -lpthread, -ldl
   and other libraries with known full path:
     /home/anibal/apps/lib/libqgis_core.so
   CMake is adding directories in the second list to the linker search
path in
   case they are needed to find libraries from the first list (for
backwards
   compatibility with CMake 2.4).  Set policy CMP0003 to OLD or NEW to
enable
   or disable this behavior explicitly.  Run "cmake --help-policy
CMP0003" for
   more information.
 This warning is for project developers.  Use -Wno-dev to suppress it.
If I try with cmake .. and after make:
debialinmov:/home/anibal/dev/cst/2_basic_main_window/build# make
[ 14%] Generating ui_mainwindowbase.h
[ 28%] Generating moc_mainwindow.cxx
[ 42%] Generating qrc_resources.cxx
Scanning dependencies of target timtut2
[ 57%] Building CXX object CMakeFiles/timtut2.dir/main.o
[ 71%] Building CXX object CMakeFiles/timtut2.dir/mainwindow.o
[ 85%] Building CXX object CMakeFiles/timtut2.dir/moc_mainwindow.o
[100%] Building CXX object CMakeFiles/timtut2.dir/qrc_resources.o
Linking CXX executable timtut2
/home/anibal/apps/lib/libqgis_core.so: undefined reference to
`QStandardItemModel::mimeTypes() const'
`QPainter::drawImage(QPointF const&, QImage const&)'
/home/anibal/apps/lib/libqgis_gui.so: undefined reference to
`QPainter::fillRect(QRect const&, QColor const&)'
`QFileDialog::setVisible(bool)'
`QStandardItemModel::dropMimeData(QMimeData const*, Qt::DropAction, int,
int, QModelIndex const&)'
`QStandardItemModel::mimeData(QList<QModelIndex> const&) const'
`QPainter::drawPixmap(QPointF const&, QPixmap const&)'
`qFlagLocation(char const*)'
collect2: ld returned 1 exit status
make[2]: *** [timtut2] Error 1
make[1]: *** [CMakeFiles/timtut2.dir/all] Error 2
make: *** [all] Error 2
Sorry, but I want to migrate my applications (mbx) on MapInfo and now I
know where to start...
:-)  ==  QGIS
Best regards
Anibal
El jue, 13-08-2009 a las 17:10 -0500, anibal alarcon escribió:
> Hi Tim
> Thanks for your answer.
> The files .so are located in /home/anibal/apps/lib
> anibal at debialinmov:~/apps/lib$ ls
> libqgis_core.so        libqgis_gui.so        libqgispython.so
> libqgispython.so.1.2.0
> libqgis_core.so.1.2.0  libqgis_gui.so.1.2.0  libqgispython.so.1.2  qgis
> How I known if there are the actual?
> Your excellent work is a good way forward.
> Best regards
> Anibal
> El jue, 13-08-2009 a las 23:42 +0200, Tim Sutton escribió:
> > -----BEGIN PGP SIGNED MESSAGE-----
> > Hash: SHA1
> > Hi Anibal
> > QGIS_CORE_LIBRARY                /home/anibal/apps/lib
> > QGIS_GUI_LIBRARY                 /home/anibal/apps/lib
> > I think the above should be pointing to the actual .so files ie.
> > libqgis_core and libqgis_gui.
> > Regards
> > Tim
> > anibal alarcon wrote:
> > > Hello list
> > > My Qgis Daphnis 1.2.0 been properly compiled in Debian5
> > > (/home/anibal/apps), but I have troubles with Tim Sutton´s Tutorial
> > > My parameters for Tutorial2
> > > after ccmake ..
> > >  CMAKE_BACKWARDS_COMPATIBILITY
> > > 2.4
> > > CMAKE_BUILD_TYPE
> > > CMAKE_INSTALL_PREFIX             /home/anibal/aplica
> > > EXECUTABLE_OUTPUT_PATH
> > > GDAL_CONFIG                      /usr/bin/gdal-config
> > > GDAL_CONFIG_PREFER_PATH          /bin
> > > GDAL_INCLUDE_DIR                 /usr/include/gdal
> > > GDAL_LIBRARY                     /usr/lib/libgdal1.5.0.so
> > > GEOS_INCLUDE_DIR                 /usr/include
> > > GEOS_LIBRARY                     /usr/lib/libgeos.so
> > > LIBRARY_OUTPUT_PATH
> > > QGIS_INCLUDE_DIR                 /home/anibal/apps/include/qgis
> > > QGIS_PLUGIN_DIR                  /home/anibal/apps/lib/qgis
> > > QT_QMAKE_EXECUTABLE              /home/anibal/qtsdk-2009.03/qt/bin/qmake
> > > After c
> > >  CMake Warning (dev) at CMakeLists.txt:22 (ADD_DEFINITIONS):
> > >    Policy CMP0005 is not set: Preprocessor definition values are now
> > > escaped
> > >    automatically.  Run "cmake --help-policy CMP0005" for policy details.
> > > Use
> > >    the cmake_policy command to set the policy and suppress this warning.
> > >  CMake Warning (dev) at CMakeLists.txt:23 (ADD_DEFINITIONS):
> > > escaped
> > > Use
> > >  CMake Warning (dev) in CMakeLists.txt:
> > >    No cmake_minimum_required command is present.  A line of code such as
> > >      cmake_minimum_required(VERSION 2.6)
> > >    should be added at the top of the file.  The version specified may be
> > > lower
> > >    if you wish to support older CMake versions for this project.  For
> > > more
> > >    information run "cmake --help-policy CMP0000".
> > > After g
> > > WARNING: Target "timtut2" requests linking to directory
> > > "/home/anibal/apps/lib".  Targets may link only to libraries.  CMake is
> > > dropping the
> > >  item.
> > > dropping the
> > >  item.
> > > And of course my /home/anibal/aplica is empty
> > > I appreciate any help in advance
> > > Best regards
> > > Anibal
> > > Only separated by what unites us, the geography
> > > _______________________________________________
> > > Qgis-developer mailing list
> > > Qgis-developer at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> > Please do not email me off-list with technical
> > support questions. Using the lists will gain
> > more exposure for your issues and the knowledge
> > surrounding your issue will be shared with all.
> > Visit http://linfiniti.com to find out about:
> >  * QGIS programming and support services
> >  * Mapserver and PostGIS based hosting plans
> >  * FOSS Consulting Services
> > Skype: timlinux
> > Irc: timlinux on #qgis at freenode.net
> > -----BEGIN PGP SIGNATURE-----
> > Version: GnuPG v1.4.9 (GNU/Linux)
> > Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> > iEYEARECAAYFAkqEiKsACgkQqk07qZdiYjfNXQCfYoC76MDC5+nDzV31uAVacTZC
> > 6loAniLjmsf0jprff1ZsVAKRlHAE7jsq
> > =E6Hr
> > -----END PGP SIGNATURE-----
