[Qgis-developer] Probably all busy, but again: compiling
troubles...
anibal alarcon
anibal.alarcon at gmail.com
Thu Aug 13 18:10:43 EDT 2009
Hi Tim
Thanks for your answer.
The files .so are located in /home/anibal/apps/lib
anibal at debialinmov:~/apps/lib$ ls
libqgis_core.so libqgis_gui.so libqgispython.so
libqgispython.so.1.2.0
libqgis_core.so.1.2.0 libqgis_gui.so.1.2.0 libqgispython.so.1.2 qgis
How I known if there are the actual?
Your excellent work is a good way forward.
Best regards
Anibal
El jue, 13-08-2009 a las 23:42 +0200, Tim Sutton escribió:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Anibal
> QGIS_CORE_LIBRARY /home/anibal/apps/lib
> QGIS_GUI_LIBRARY /home/anibal/apps/lib
> I think the above should be pointing to the actual .so files ie.
> libqgis_core and libqgis_gui.
> Regards
> Tim
> anibal alarcon wrote:
> > Hello list
> > My Qgis Daphnis 1.2.0 been properly compiled in Debian5
> > (/home/anibal/apps), but I have troubles with Tim Sutton´s Tutorial
> > My parameters for Tutorial2
> > after ccmake ..
> > CMAKE_BACKWARDS_COMPATIBILITY
> > 2.4
> > CMAKE_BUILD_TYPE
> > CMAKE_INSTALL_PREFIX /home/anibal/aplica
> > EXECUTABLE_OUTPUT_PATH
> > GDAL_CONFIG /usr/bin/gdal-config
> > GDAL_CONFIG_PREFER_PATH /bin
> > GDAL_INCLUDE_DIR /usr/include/gdal
> > GDAL_LIBRARY /usr/lib/libgdal1.5.0.so
> > GEOS_INCLUDE_DIR /usr/include
> > GEOS_LIBRARY /usr/lib/libgeos.so
> > LIBRARY_OUTPUT_PATH
> > QGIS_INCLUDE_DIR /home/anibal/apps/include/qgis
> > QGIS_PLUGIN_DIR /home/anibal/apps/lib/qgis
> > QT_QMAKE_EXECUTABLE /home/anibal/qtsdk-2009.03/qt/bin/qmake
> > After c
> > CMake Warning (dev) at CMakeLists.txt:22 (ADD_DEFINITIONS):
> > Policy CMP0005 is not set: Preprocessor definition values are now
> > escaped
> > automatically. Run "cmake --help-policy CMP0005" for policy details.
> > Use
> > the cmake_policy command to set the policy and suppress this warning.
> > This warning is for project developers. Use -Wno-dev to suppress it.
> > CMake Warning (dev) at CMakeLists.txt:23 (ADD_DEFINITIONS):
> > escaped
> > Use
> > CMake Warning (dev) in CMakeLists.txt:
> > No cmake_minimum_required command is present. A line of code such as
> > cmake_minimum_required(VERSION 2.6)
> > should be added at the top of the file. The version specified may be
> > lower
> > if you wish to support older CMake versions for this project. For
> > more
> > information run "cmake --help-policy CMP0000".
> > After g
> > WARNING: Target "timtut2" requests linking to directory
> > "/home/anibal/apps/lib". Targets may link only to libraries. CMake is
> > dropping the
> > item.
> > dropping the
> > item.
> > And of course my /home/anibal/aplica is empty
> > I appreciate any help in advance
> > Best regards
> > Anibal
> > Only separated by what unites us, the geography
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAkqEiKsACgkQqk07qZdiYjfNXQCfYoC76MDC5+nDzV31uAVacTZC
> 6loAniLjmsf0jprff1ZsVAKRlHAE7jsq
> =E6Hr
> -----END PGP SIGNATURE-----
