[Qgis-developer] Probably all busy,
but again: compiling troubles...
Tim Sutton
lists at linfiniti.com
Thu Aug 13 17:42:09 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Anibal
QGIS_CORE_LIBRARY /home/anibal/apps/lib
QGIS_GUI_LIBRARY /home/anibal/apps/lib
I think the above should be pointing to the actual .so files ie.
libqgis_core and libqgis_gui.
Regards
Tim
anibal alarcon wrote:
> Hello list
> My Qgis Daphnis 1.2.0 been properly compiled in Debian5
> (/home/anibal/apps), but I have troubles with Tim Sutton´s Tutorial
> My parameters for Tutorial2
> after ccmake ..
> CMAKE_BACKWARDS_COMPATIBILITY
> 2.4
> CMAKE_BUILD_TYPE
> CMAKE_INSTALL_PREFIX /home/anibal/aplica
> EXECUTABLE_OUTPUT_PATH
> GDAL_CONFIG /usr/bin/gdal-config
> GDAL_CONFIG_PREFER_PATH /bin
> GDAL_INCLUDE_DIR /usr/include/gdal
> GDAL_LIBRARY /usr/lib/libgdal1.5.0.so
> GEOS_INCLUDE_DIR /usr/include
> GEOS_LIBRARY /usr/lib/libgeos.so
> LIBRARY_OUTPUT_PATH
> QGIS_INCLUDE_DIR /home/anibal/apps/include/qgis
> QGIS_PLUGIN_DIR /home/anibal/apps/lib/qgis
> QT_QMAKE_EXECUTABLE /home/anibal/qtsdk-2009.03/qt/bin/qmake
> After c
> CMake Warning (dev) at CMakeLists.txt:22 (ADD_DEFINITIONS):
> Policy CMP0005 is not set: Preprocessor definition values are now
> escaped
> automatically. Run "cmake --help-policy CMP0005" for policy details.
> Use
> the cmake_policy command to set the policy and suppress this warning.
> This warning is for project developers. Use -Wno-dev to suppress it.
> CMake Warning (dev) at CMakeLists.txt:23 (ADD_DEFINITIONS):
> escaped
> Use
> CMake Warning (dev) in CMakeLists.txt:
> No cmake_minimum_required command is present. A line of code such as
> cmake_minimum_required(VERSION 2.6)
> should be added at the top of the file. The version specified may be
> lower
> if you wish to support older CMake versions for this project. For
> more
> information run "cmake --help-policy CMP0000".
> After g
> WARNING: Target "timtut2" requests linking to directory
> "/home/anibal/apps/lib". Targets may link only to libraries. CMake is
> dropping the
> item.
> dropping the
> item.
> And of course my /home/anibal/aplica is empty
> I appreciate any help in advance
> Best regards
> Anibal
> Only separated by what unites us, the geography
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkqEiKsACgkQqk07qZdiYjfNXQCfYoC76MDC5+nDzV31uAVacTZC
6loAniLjmsf0jprff1ZsVAKRlHAE7jsq
=E6Hr
-----END PGP SIGNATURE-----
