[Qgis-developer]
Probably all busy, but again: compiling troubles...
anibal alarcon
anibal.alarcon at gmail.com
Thu Aug 13 11:28:15 EDT 2009
Hello list
My Qgis Daphnis 1.2.0 been properly compiled in Debian5
(/home/anibal/apps), but I have troubles with Tim SuttonĀ“s Tutorial
My parameters for Tutorial2
after ccmake ..
CMAKE_BACKWARDS_COMPATIBILITY
2.4
CMAKE_BUILD_TYPE
CMAKE_INSTALL_PREFIX /home/anibal/aplica
EXECUTABLE_OUTPUT_PATH
GDAL_CONFIG /usr/bin/gdal-config
GDAL_CONFIG_PREFER_PATH /bin
GDAL_INCLUDE_DIR /usr/include/gdal
GDAL_LIBRARY /usr/lib/libgdal1.5.0.so
GEOS_INCLUDE_DIR /usr/include
GEOS_LIBRARY /usr/lib/libgeos.so
LIBRARY_OUTPUT_PATH
QGIS_CORE_LIBRARY /home/anibal/apps/lib
QGIS_GUI_LIBRARY /home/anibal/apps/lib
QGIS_INCLUDE_DIR /home/anibal/apps/include/qgis
QGIS_PLUGIN_DIR /home/anibal/apps/lib/qgis
QT_QMAKE_EXECUTABLE /home/anibal/qtsdk-2009.03/qt/bin/qmake
After c
CMake Warning (dev) at CMakeLists.txt:22 (ADD_DEFINITIONS):
Policy CMP0005 is not set: Preprocessor definition values are now
escaped
automatically. Run "cmake --help-policy CMP0005" for policy details.
Use
the cmake_policy command to set the policy and suppress this warning.
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning (dev) at CMakeLists.txt:23 (ADD_DEFINITIONS):
escaped
Use
CMake Warning (dev) in CMakeLists.txt:
No cmake_minimum_required command is present. A line of code such as
cmake_minimum_required(VERSION 2.6)
should be added at the top of the file. The version specified may be
lower
if you wish to support older CMake versions for this project. For
more
information run "cmake --help-policy CMP0000".
After g
WARNING: Target "timtut2" requests linking to directory
"/home/anibal/apps/lib". Targets may link only to libraries. CMake is
dropping the
item.
dropping the
item.
And of course my /home/anibal/aplica is empty
I appreciate any help in advance
Best regards
Anibal
Only separated by what unites us, the geography
