[Qgis-developer] Re: Posting parameters for the various Qt libs
Tim Sutton
lists at linfiniti.com
Sun Aug 16 17:14:34 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
Please don't attach such large attachments unless they are solicited. In
general you should upload them to a photo sharing service and just mail
the link....it will go a long way to making people want to help you if
you don't kill their slow internet connections...:-(
anibal alarcon wrote:
> Hi Tim
> I found in the list advanced mode of options after ccmake .. (t), only
> this problems (QTNETWORK thats OK):
> QT_QTMOTIF_INCLUDE_DIR
> QT_QTMOTIF_INCLUDE_DIR-NOTFOUND
> QT_QTMOTIF_LIBRARY_DEBUG
> QT_QTMOTIF_LIBRARY_DEBUG-NOTFOUND
> QT_QTMOTIF_LIBRARY_RELEASE
> QT_QTMOTIF_LIBRARY_RELEASE-NOTFOUND
> (QT_QTNETWORK_INCLUDE_DIR /usr/include/qt4/QtNetwork
> QT_QTNETWORK_LIBRARY /usr/lib/libQtNetwork.so
> QT_QTNETWORK_LIBRARY_DEBUG
> QT_QTNETWORK_LIBRARY_DEBUG-NOTFOUND
> QT_QTNETWORK_LIBRARY_RELEASE /usr/lib/libQtNetwork.so)
> QT_QTNSPLUGIN_INCLUDE_DIR
> QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND
> QT_QTNSPLUGIN_LIBRARY_DEBUG
> QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND
> QT_QTNSPLUGIN_LIBRARY_RELEASE
> QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND
> For the rest are just missing debug (QT_QTXX_LIBRARY_DEBUG-NOTFOUND),
> which is the QTMOTIF_LIBRARY and the QTNSPLUGIN_LIBRARY ? where are
> they?
NSPLUGIN and MOTIF stuff you can safely ignore I think. I did a test
build of timtut2 here just to be sure it was all still working ok. It
compiles fine against QGIS 1.2 'Daphnis'. Here is what I have on my
ccmake screen:
CMAKE_BACKWARDS_COMPATIBILITY 2.4
CMAKE_BUILD_TYPE
CMAKE_INSTALL_PREFIX /usr/local
EXECUTABLE_OUTPUT_PATH
GDAL_CONFIG /home/timlinux/apps/bin/gdal-config
GDAL_CONFIG_PREFER_PATH /bin
GDAL_INCLUDE_DIR /usr/local/include
GDAL_LIBRARY /usr/lib/libgdal1.6.0.so
GEOS_INCLUDE_DIR /usr/include
GEOS_LIBRARY /usr/lib/libgeos.so
LIBRARY_OUTPUT_PATH
QGIS_CORE_LIBRARY
/home/timlinux/apps/qgis_trunk/lib/libqgis_core.so
QGIS_GUI_LIBRARY
/home/timlinux/apps/qgis_trunk/lib/libqgis_gui.so
QGIS_INCLUDE_DIR
/home/timlinux/apps/qgis_trunk/include/qgis
QGIS_PLUGIN_DIR
/home/timlinux/apps/qgis_trunk/lib/qgis
QT_QMAKE_EXECUTABLE /usr/bin/qmake
Also check your QGIS_INCLUDE_DIR (press 't' first to toggle on advanced
settings) is set correctly - on my system it looks like:
QT_QT_INCLUDE_DIR /usr/include/qt4/Qt
Hope that helps. I suggest asking your tiff question in a separate
thread as it will be lost to other devs if you bury it in an existing
thread.
Regards
Tim
> Thanks for the help
> Anibal
> Otherwise, I was trying QGIS with plugin Mapnik and work fine, but my
> hacker google images ( :P ) that are geoTIFF are displayed in black &
> white ...
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkqIdrMACgkQqk07qZdiYjcaewCfZDp4BE8TLckEeiQvV2ZGoFTu
DFUAoMqrb+rHwGvDZQn9pq4ZeS02hA0W
=UhBw
-----END PGP SIGNATURE-----
