[Qgis-developer] Re: Posting parameters for the various Qt libs
anibal alarcon anibal.alarcon at gmail.com
Sun Aug 16 20:40:53 EDT 2009
Hi Tim
I apologize for any inconvenience.
Thanks for your help
Regards
Anibal
El dom, 16-08-2009 a las 23:14 +0200, Tim Sutton escribió:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi
> Please don't attach such large attachments unless they are solicited. In
> general you should upload them to a photo sharing service and just mail
> the link....it will go a long way to making people want to help you if
> you don't kill their slow internet connections...:-(
> anibal alarcon wrote:
> > Hi Tim
> > I found in the list advanced mode of options after ccmake .. (t), only
> > this problems (QTNETWORK thats OK):
> > QT_QTMOTIF_INCLUDE_DIR
> > QT_QTMOTIF_INCLUDE_DIR-NOTFOUND
> >  QT_QTMOTIF_LIBRARY_DEBUG
> > QT_QTMOTIF_LIBRARY_DEBUG-NOTFOUND
> >  QT_QTMOTIF_LIBRARY_RELEASE
> > QT_QTMOTIF_LIBRARY_RELEASE-NOTFOUND
> >  (QT_QTNETWORK_INCLUDE_DIR         /usr/include/qt4/QtNetwork
> > QT_QTNETWORK_LIBRARY             /usr/lib/libQtNetwork.so
> >  QT_QTNETWORK_LIBRARY_DEBUG
> > QT_QTNETWORK_LIBRARY_DEBUG-NOTFOUND
> >  QT_QTNETWORK_LIBRARY_RELEASE     /usr/lib/libQtNetwork.so)
> >  QT_QTNSPLUGIN_INCLUDE_DIR
> > QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND
> >  QT_QTNSPLUGIN_LIBRARY_DEBUG
> > QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND
> >  QT_QTNSPLUGIN_LIBRARY_RELEASE
> > QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND
> > For the rest are just missing debug (QT_QTXX_LIBRARY_DEBUG-NOTFOUND),
> > which is the QTMOTIF_LIBRARY and the QTNSPLUGIN_LIBRARY ? where are
> > they?
> NSPLUGIN and MOTIF stuff you can safely ignore I think. I did a test
> build of timtut2 here just to be sure it was all still working ok. It
> compiles fine against QGIS 1.2 'Daphnis'. Here is what I have on my
> ccmake screen:
>  CMAKE_BACKWARDS_COMPATIBILITY    2.4
>  CMAKE_BUILD_TYPE
>  CMAKE_INSTALL_PREFIX             /usr/local
>  EXECUTABLE_OUTPUT_PATH
>  GDAL_CONFIG                      /home/timlinux/apps/bin/gdal-config
>  GDAL_CONFIG_PREFER_PATH          /bin
>  GDAL_INCLUDE_DIR                 /usr/local/include
>  GDAL_LIBRARY                     /usr/lib/libgdal1.6.0.so
>  GEOS_INCLUDE_DIR                 /usr/include
>  GEOS_LIBRARY                     /usr/lib/libgeos.so
>  LIBRARY_OUTPUT_PATH
>  QGIS_CORE_LIBRARY
> /home/timlinux/apps/qgis_trunk/lib/libqgis_core.so
>  QGIS_GUI_LIBRARY
> /home/timlinux/apps/qgis_trunk/lib/libqgis_gui.so
>  QGIS_INCLUDE_DIR
> /home/timlinux/apps/qgis_trunk/include/qgis
>  QGIS_PLUGIN_DIR
> /home/timlinux/apps/qgis_trunk/lib/qgis
>  QT_QMAKE_EXECUTABLE              /usr/bin/qmake
> Also check your QGIS_INCLUDE_DIR (press 't' first to toggle on advanced
> settings) is set correctly - on my system it looks like:
>  QT_QT_INCLUDE_DIR                /usr/include/qt4/Qt
> Hope that helps. I suggest asking your tiff question in a separate
> thread as it will be lost to other devs if you bury it in an existing
> thread.
> Regards
> Tim
> > Thanks for the help
> > Anibal
> > Otherwise, I was trying QGIS with plugin Mapnik and work fine, but my
> > hacker google images ( :P ) that are geoTIFF are displayed in black &
> > white ...
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAkqIdrMACgkQqk07qZdiYjcaewCfZDp4BE8TLckEeiQvV2ZGoFTu
> DFUAoMqrb+rHwGvDZQn9pq4ZeS02hA0W
> =UhBw
> -----END PGP SIGNATURE-----
