[Qgis-developer] Re: Posting parameters for the various Qt libs
Tim Sutton
lists at linfiniti.com
Mon Aug 17 08:06:00 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
(thread back on list)
anibal alarcon wrote:
> Hi Tim
> I did the following:
> 1. Unisntalled qgis(1.1) and his bindings except python-qgis 1.1.0
> 2. Again built qgis 1.2 in another path (/home/anibal/aplica) and work
> fine, except at the end:
> -- Installing: /home/anibal/aplica/share/qgis/i18n/qgis_sq_AL.qm
> -- Installing: /home/anibal/aplica/share/qgis/i18n/qt_ar.qm
> -- Installing: /usr/lib/python2.5/site-packages/qgis/__init__.py
> CMake Error at python/cmake_install.cmake:36 (FILE):
> file INSTALL cannot copy file
> "/home/anibal/dev/cpp/qgis/python/__init__.py" to
> "/usr/lib/python2.5/site-packages/qgis/__init__.py".
> Call Stack (most recent call first):
> cmake_install.cmake:64 (INCLUDE)
> make: *** [install] Error 1
> but built qgis executable.
Ok this is a general QGIS compilation error you should ask on the list.
There have been quite a few python related updates in the last few days
and you may have caught a snapshot in the middle of them. Try updating
svn and then doing:
cd build
ccmake ..
c
g
make install
(to force regeneration of make files)
> 3. Deleted the directory 1_hello_world_qgis_style
> 4. Again svn co
> https://svn.osgeo.org/qgis/trunk/code_examples/1_hello_world_qgis_style
> cd 1_hello_world_qgis_style
> mkdir build
> export LIB_DIR=/home/anibal/aplica
> cmake ..
> make
> I modified in main.cpp (prueba.shp exist)
> QString myPluginsDir = "/home/anibal/apps/lib/qgis";
> QString myLayerPath = "/home/anibal/gnu2win/";
> QString myLayerBaseName = "prueba";
> QString myProviderName = "ogr";
Did you say you used 'aplica' as your qgis install path? mPluginsDir
should match...
> After cmake .. some warnings but said:
> -- Generating done
> -- Build files have been written
> to: /home/anibal/dev/cst/1_hello_world_qgis_style/build
> After make
> anibal at debialinmov:~/dev/cst/1_hello_world_qgis_style/build$ make
> Linking CXX executable timtut1
> /home/anibal/aplica/lib/libqgis_core.so: undefined reference to
> `QStandardItemModel::mimeTypes() const'
> `QPainter::drawImage(QPointF const&, QImage const&)'
> /home/anibal/aplica/lib/libqgis_gui.so: undefined reference to
> `QPainter::fillRect(QRect const&, QColor const&)'
> `QFileDialog::setVisible(bool)'
> `QStandardItemModel::dropMimeData(QMimeData const*, Qt::DropAction, int,
> int, QModelIndex const&)'
> `QStandardItemModel::mimeData(QList<QModelIndex> const&) const'
> `QPainter::drawPixmap(QPointF const&, QPixmap const&)'
> `qFlagLocation(char const*)'
> collect2: ld returned 1 exit status
> make[2]: *** [timtut1] Error 1
> make[1]: *** [CMakeFiles/timtut1.dir/all] Error 2
> make: *** [all] Error 2
Run ldd on your generated binary and check that it has libs referenced
properly for each (in particular Qt) lib. See my example below this
message. If not you should either:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:<path to qt lib dir>
or (system wide so use sudo)
edit /etc/ld.so.conf
add the path to qt lib dir there
run ldconfig
Then try to run the binary again.
Regards
Tim
[build] ldd timtut1
linux-vdso.so.1 => (0x00007fffa7bff000)
libQtSvg.so.4 => /usr/lib/libQtSvg.so.4 (0x00007f689f736000)
libQtGui.so.4 => /usr/lib/libQtGui.so.4 (0x00007f689eaf8000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x00007f689e8e6000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x00007f689e5df000)
libQtXml.so.4 => /usr/lib/libQtXml.so.4 (0x00007f689e397000)
libQtSql.so.4 => /usr/lib/libQtSql.so.4 (0x00007f689e157000)
libQtNetwork.so.4 => /usr/lib/libQtNetwork.so.4 (0x00007f689de33000)
libQtCore.so.4 => /usr/lib/libQtCore.so.4 (0x00007f689d9e6000)
libpthread.so.0 => /lib/libpthread.so.0 (0x00007f689d7ca000)
libdl.so.2 => /lib/libdl.so.2 (0x00007f689d5c6000)
libqgis_core.so.1.2.0 =>
/home/timlinux/apps/qgis_trunk/lib/libqgis_core.so.1.2.0
(0x00007f689cf70000)
libqgis_gui.so.1.2.0 =>
/home/timlinux/apps/qgis_trunk/lib/libqgis_gui.so.1.2.0 (0x00007f689ccd2000)
libgeos-3.1.0.so => /usr/lib/libgeos-3.1.0.so (0x00007f689c98a000)
libgdal1.6.0.so.1 => /usr/lib/libgdal1.6.0.so.1 (0x00007f689c018000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007f689bd0b000)
libm.so.6 => /lib/libm.so.6 (0x00007f689ba86000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007f689b86e000)
libc.so.6 => /lib/libc.so.6 (0x00007f689b4fc000)
libz.so.1 => /lib/libz.so.1 (0x00007f689b2e4000)
libaudio.so.2 => /usr/lib/libaudio.so.2 (0x00007f689b0cb000)
libpng12.so.0 => /usr/lib/libpng12.so.0 (0x00007f689aea4000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x00007f689ac1e000)
libgobject-2.0.so.0 => /usr/lib/libgobject-2.0.so.0 (0x00007f689a9d8000)
libSM.so.6 => /usr/lib/libSM.so.6 (0x00007f689a7cf000)
libICE.so.6 => /usr/lib/libICE.so.6 (0x00007f689a5b4000)
libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0x00007f689a2ef000)
libXrender.so.1 => /usr/lib/libXrender.so.1 (0x00007f689a0e5000)
libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0x00007f6899eb3000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x00007f6899cb0000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00007f6899a94000)
libgthread-2.0.so.0 => /usr/lib/libgthread-2.0.so.0 (0x00007f689988f000)
librt.so.1 => /lib/librt.so.1 (0x00007f6899687000)
/lib64/ld-linux-x86-64.so.2 (0x00007f689f98f000)
libproj.so.0 => /usr/lib/libproj.so.0 (0x00007f6899446000)
libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00007f6899232000)
libgdal.so.1 => /home/timlinux/apps/lib/libgdal.so.1 (0x00007f6898889000)
libsqlite3.so.0 => /usr/lib/libsqlite3.so.0 (0x00007f6898602000)
libodbc.so.1 => /usr/lib/libodbc.so.1 (0x00007f68983a0000)
libodbcinst.so.1 => /usr/lib/libodbcinst.so.1 (0x00007f6898193000)
libltdl.so.7 => /usr/lib/libltdl.so.7 (0x00007f6897f89000)
libexpat.so.1 => /usr/lib/libexpat.so.1 (0x00007f6897d5f000)
libxerces-c.so.28 => /usr/lib/libxerces-c.so.28 (0x00007f6897787000)
libjasper.so.1 => /usr/lib/libjasper.so.1 (0x00007f689752f000)
libhdf5-1.6.6.so.0 => /usr/lib/libhdf5-1.6.6.so.0 (0x00007f689720e000)
libmfhdf.so.4 => /usr/lib/libmfhdf.so.4 (0x00007f6896fe6000)
libdf.so.4 => /usr/lib/libdf.so.4 (0x00007f6896d34000)
libogdi.so.3.2 => /usr/lib/libogdi.so.3.2 (0x00007f6896b14000)
libgif.so.4 => /usr/lib/libgif.so.4 (0x00007f689690b000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x00007f68966e8000)
libnetcdf.so.4 => /usr/lib/libnetcdf.so.4 (0x00007f68964b4000)
libpq.so.5 => /usr/lib/libpq.so.5 (0x00007f689628f000)
libcurl-gnutls.so.4 => /usr/lib/libcurl-gnutls.so.4 (0x00007f6896051000)
libidn.so.11 => /usr/lib/libidn.so.11 (0x00007f6895e1e000)
liblber-2.4.so.2 => /usr/lib/liblber-2.4.so.2 (0x00007f6895c0f000)
libldap_r-2.4.so.2 => /usr/lib/libldap_r-2.4.so.2 (0x00007f68959c6000)
libgssapi_krb5.so.2 => /usr/lib/libgssapi_krb5.so.2 (0x00007f6895799000)
libgnutls.so.26 => /usr/lib/libgnutls.so.26 (0x00007f68954ec000)
libtasn1.so.3 => /usr/lib/libtasn1.so.3 (0x00007f68952db000)
libgcrypt.so.11 => /lib/libgcrypt.so.11 (0x00007f6895074000)
libmysqlclient.so.15 => /usr/lib/libmysqlclient.so.15 (0x00007f6894c75000)
libcrypt.so.1 => /lib/libcrypt.so.1 (0x00007f6894a3d000)
libnsl.so.1 => /lib/libnsl.so.1 (0x00007f6894823000)
libXt.so.6 => /usr/lib/libXt.so.6 (0x00007f68945bd000)
libpcre.so.3 => /lib/libpcre.so.3 (0x00007f689438d000)
libuuid.so.1 => /lib/libuuid.so.1 (0x00007f6894188000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00007f6893f83000)
libgeos-3.0.0.so => /usr/lib/libgeos-3.0.0.so (0x00007f6893c52000)
libtiff.so.4 => /usr/lib/libtiff.so.4 (0x00007f68939f7000)
libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0x00007f689375c000)
libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0x00007f6893537000)
libcom_err.so.2 => /lib/libcom_err.so.2 (0x00007f6893333000)
libicuuc.so.38 => /usr/lib/libicuuc.so.38 (0x00007f6892ff1000)
libicudata.so.38 => /usr/lib/libicudata.so.38 (0x00007f689231b000)
libssl.so.0.9.8 => /usr/lib/libssl.so.0.9.8 (0x00007f68920cc000)
libcrypto.so.0.9.8 => /usr/lib/libcrypto.so.0.9.8 (0x00007f6891d43000)
libresolv.so.2 => /lib/libresolv.so.2 (0x00007f6891b2b000)
libsasl2.so.2 => /usr/lib/libsasl2.so.2 (0x00007f6891911000)
libkrb5support.so.0 => /usr/lib/libkrb5support.so.0 (0x00007f6891709000)
libkeyutils.so.1 => /lib/libkeyutils.so.1 (0x00007f6891506000)
libgpg-error.so.0 => /lib/libgpg-error.so.0 (0x00007f6891303000)
> nothing has changed, everything remains the same and of course to review
> your comments
> QT_QT_INCLUDE_DIR /usr/include/qt4/Qt
> is the same that I have
> I installed the last open source Qt4 from
> http://qt.nokia.com/downloads/sdk-linux-x11-32bit-cpp
> thanks friend
> Best regards
> Anibal
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkqJR5wACgkQqk07qZdiYjenSQCfVtuyuGTumOPBj5+ToyTXVtnS
5qQAoL6vcpiEq2C5a7P/pc18xpfalYfj
=Iffw
-----END PGP SIGNATURE-----
