[Qgis-developer] Re: symbology-ng build
John C. Tull jctull at gmail.com
Mon Aug 17 20:40:58 EDT 2009
This is great progress. I am able to get the symbology classified and
used on a quick test of a roads file. I did not play around with
creating new symbols. Labels do not appear to be working. I did not
see an option for labels following lines, etc. I assume that is still
underway, perhaps lacking the appropriate means to enact this via the
properties dialog. Choosing to display labels and selecting a name
field did not produce any labels on the canvas.
Thank you much,
John
On Aug 17, 2009, at 5:17 PM, Martin Dobias wrote:
> On Tue, Aug 18, 2009 at 2:12 AM, John C. Tull<jctull at gmail.com> wrote:
>> That seems to have worked and things are getting farther:
>> Creating qgisconfig.py...
>> Done
>> [ 60%] Generating core/core.so
>> /System/Library/Frameworks/Python.framework/Versions/2.5/share/sip/
>> PyQt4/QtCore/qlist.sip:
>> In function ‘int
>> convertTo_QList_27000600QList_0200QgsSymbolV2LevelItem(PyObject*,
>> void**,
>> int*, PyObject*)’:
>> PyQt4/QtCore/qlist.sip:85:
>> error: ‘sipType_QgsSymbolV2Level’ was not declared in this scope
>> PyQt4/QtCore/qlist.sip:103:
>> In function ‘PyObject*
>> convertFrom_QList_27000600QList_0200QgsSymbolV2LevelItem(void*,
>> PyObject*)’:
>> PyQt4/QtCore/qlist.sip:59:
> Try again with r11421.
> Cheers
> Martin
