[Qgis-developer] Default project settings
Magnus Homann magnus at homann.se
Wed Aug 26 09:36:24 EDT 2009
Some feature requests has to do with setting default project properties. Implementing that
is probably a good idea.
Could a solution be to create the concept of "default.qgs", an empty project that gets read every time QGIS starts
and every time "New project..." is selected. Everything but the layers(?) will be read from the default.qgs, stored
next to users .qgis db.
A button in project properties for "Save as defaulut setting..." is the UI changes that is needed?
Thoughts?
Magnus
