[Qgis-developer] Default project settings
Andreas Neumann
a.neumann at carto.net
Wed Aug 26 15:51:23 EDT 2009
+1 from me.
Having a default project would solve several problems at once. One could
have default units, projection, digitizing settings, selection and
background colors, etc.
One would have to issue a warning though, if the default.qgs is from an
old QGIS version.
Andreas
Magnus Homann wrote:
> Some feature requests has to do with setting default project
> properties. Implementing that
> is probably a good idea.
> Could a solution be to create the concept of "default.qgs", an empty
> project that gets read every time QGIS starts
> and every time "New project..." is selected. Everything but the
> layers(?) will be read from the default.qgs, stored
> next to users .qgis db.
> A button in project properties for "Save as defaulut setting..." is
> the UI changes that is needed?
> Thoughts?
> Magnus
> Qgis-developer mailing list
