[Qgis-developer] symbol lookup error:
/usr/lib/libqgisgrass.so.1.2.0: undefined symbol: G_no_gisinit
Matthew Denno
mgdenno at gmail.com
Fri Aug 28 08:21:37 EDT 2009
Hi Agus,
I don't know specifically about your errors, but I installed the
latest unstable version from the repositories at:
https://launchpad.net/~qgis/+archive/unstable. Maybe you want to add
these repositories and see if it works for you.
Matt
On Fri, Aug 28, 2009 at 6:39 AM, Agustin Lobo<alobolistas at gmail.com> wrote:
> Hi!
> After upgrading to qgis 1.2.01~jaunty, qgis does not start.
> If I run qgis from a terminal, I get:
> /usr/bin/qgis.bin: symbol lookup error: /usr/lib/libqgisgrass.so.1.2.0:
> I've tried
> ~$ sudo apt-get install libqgis
> Reading package lists... Done
> Building dependency tree Reading state information... Done
> E: Couldn't find package libqgis
> I've reinstalled libqgis1.2.0_1.2.0-1~jaunty1_i386.deb
> <https://launchpad.net/%7Eubuntugis/+archive/ubuntugis-unstable/+files/libqgis1.2.0_1.2.0-1%7Ejaunty1_i386.deb>
> from
> https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
> but still have the same problem
> Is this a problem with the package or am I doing something wrong?
> Thanks for any advice
> Agus
> Qgis-developer mailing list
