[Qgis-developer] Re: qgsRelate (Table joins in QGIS)
John C. Tull
john.tull at wildnevada.org
Sun Dec 27 13:43:49 EST 2009
Hi Mauricio,
Again, I do think this would be useful. Hopefully others will chime in as well.
John
On Dec 27, 2009, at 10:41 AM, Maurício de Paulo wrote:
> The idea behind this plugin is that it would use qgsvectorlayer (that supports shapefile, postgresql, grass, dbf, etc) and would join only a single feature attributes.
> So i'm proposing that the user would select a feature and would be able to find everything related to it. Every relationship could be stored in a relationship file so that you could reproduce it for a given data model.
> It's a major problem in Brasil because we defined a new spatial model and qgis is not able to read relationships. At least, the user should be able to build them to look for non-spatial relations of a given feature.
> Well, as soon as I have a working plugin i'm going to release it. If anyone have interest in it, please tell me so I can continue working without loosing my time. :P
> Mauricio de Paulo
> 2009/12/27 John C. Tull <john.tull at wildnevada.org>
> Hi Mauricio,
> I am interested in what you propose. Currently, fTools allows joining tables using dbf files (maybe other formats, not sure). But this produces a new shapefile. Having a means to create table joins without outputting a new file would be very useful. I am sure others would agree. Ideally, this would allow the use of multiple table formats, including postgresql, as you suggested.
> Cheers,
> John
> On Dec 26, 2009, at 8:56 PM, Maurício de Paulo wrote:
>> Well, after some testing I found out that qgis now can open dbf files as vector layers. It's enough for me to create the "relate" implementation.
>> As far as I can see, it's possible and won't take too long to implement. Will it be usefull? Is anyone already working on a full join implementation?
>> Mauricio de Paulo
>> 2009/12/26 Maurício de Paulo <mauricio.dev at gmail.com>
>> Hi folks,
>> I don't remember exactly what was defined on the last discussion about table joins.
>> I've read many good sugestions, many of them about implementing attribute relationship inside qgsvectorprovider.
>> I also work on ArcGIS and the relations and joins on ArcGIS usually don't show the full table join. It only shows the related attributes of a single feature. So for each feature, you can use a Info tool to see every attribute about it (including the ones that comes from related tables). Everything is done on the fly, but performance is not a big issue as i'm only going to search for one feature's relationships.
>> I'm using the screenshots that are attached to the mail as an example of how it should work.
>> At the moment I need some feedback on what it is or is not a good approach and if it's gonna be usefull for the users.
>> What do you guys think?
>> The idea is a plugin to record what relationships are stored for each layer and then show the attributes in a tree view where a single feature can be linked to many other rows in the second table. I still don't know how i'm going to implement it but either I will use ogr or qgsvectorprovider. I still have to search if it's possible to access the dbf files and postgis connections using qgis api.
>> Any comment is welcome.
>> Mauricio de Paulo
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20091227/84d468b6/attachment.html
