[Qgis-developer] error with new table manager plugin
Borys Jurgiel
borysiasty at aster.pl
Sun Feb 1 18:26:52 EST 2009
Monday 02 February 2009 00:09:37 Carlos Dávila napisał(a):
> > I tried to install new version, but get this message:
> > The plugin seems to have been installed but I don't know where. Probably
> > the plugin package contained a wrong named directory.
> > Please search the list of installed plugins. I'm nearly sure you'll find
> > the plugin there, but I just can't determine which of them it is. It
> > also means that I won't be able to determine if this plugin is installed
> > and inform you about available updates. However the plugin may work.
> > Please contact the plugin author and submit this issue.
> > Plugin in not in ~/.qgis/python/plugins
> I found it installed in ~/Pulpit/borysowe
Ops, I didn't test the package. It's now fixed, so please reinstall once again
and remove the ~/Pulpit/borysowe directory manually. I'm sorry!
