[Qgis-developer] error with new table manager plugin
Carlos Dávila
cdavilam at jemila.jazztel.es
Sun Feb 1 18:09:37 EST 2009
Carlos Dávila escribió:
> Borys Jurgiel escribió:
>> Paolo Cavallini escribió:
>>> "/home/paolo/.qgis//python/plugins/tablemanager/tableManager_gui.py",
>>> line 184, in drawFieldsTable
>>> item = QTableWidgetItem(fields[i].name())
>>> KeyError: 3
>> Could you provide some details please? When it occurs, with what layer?
>> Carlos Dávila napisał(a):
>>> "/home/carlos/.qgis//python/plugins/tablemanager/tableManager_gui.py",
>>> line 113, in __init__
>>> self.setWindowTitle('Insert field: '+fields[selection].name())
>>> KeyError: -1
>> Fixed!
> I tried to install new version, but get this message:
> The plugin seems to have been installed but I don't know where. Probably
> the plugin package contained a wrong named directory.
> Please search the list of installed plugins. I'm nearly sure you'll find
> the plugin there, but I just can't determine which of them it is. It
> also means that I won't be able to determine if this plugin is installed
> and inform you about available updates. However the plugin may work.
> Please contact the plugin author and submit this issue.
> Plugin in not in ~/.qgis/python/plugins
I found it installed in ~/Pulpit/borysowe
