[Qgis-developer] Better attribute table - c++ plugin
a.neumann at carto.net
Fri Feb 6 04:36:56 EST 2009
I am wondering if your Beata implementation could also handle other
widgets next to text input widgets?
In the layers' properties dialog, in the attributes tab one can define
which widget to use for the show info dialogue. Wouldn't it be cool if the
same widgets would also be used in the regular attribute table?
For performance reasons it might be good to first display a regular table,
but after a user selected a certain row for editing, the input widgets
would change to whatever the user defined in the attributes tab of the
layer properties, e.g. a range slider, selection list, etc. would be
displayed.
Do you understand what I mean or should I explain more clearly?
Andreas
> Hi all,
> I'm happy to announce on the behalf of our qgis-mapper team a new
> attribute table implementation for Quantum GIS. For those impatient,
> the source is available here:
> http://mapserver.sk/~wonder/qgis/beata-snapshot-090502.tar.gz
> To install it, copy it to your svn trunk (1.0.0 source should be fine
> too) into src/plugins/ directory. Then just edit
> src/plugins/CMakeLists.txt, add there directory "beata" and that's it
> - just compile and run!
> The new implementation (called beata - short for better attribute
> table) features:
> - using Qt model/view design
> - faster startup - the model fetches only features in the window
> - fallback model that caches everything in memory (for layer that
> don't support random access)
> - cursor in table independent from currently selected row
> - better usage of available space
> We'll be happy to hear some feedback from you!
> I hope there will be enough interest to put the plugin into SVN, and
> in case that everyone's confident with new implementation, it could
> replace the current implementation.
> Regards
> Martin
> Qgis-developer mailing list
