[Qgis-developer] Better attribute table - c++ plugin
Martin Dobias
wonder.sk at gmail.com
Fri Feb 6 08:14:59 EST 2009
On Fri, Feb 6, 2009 at 4:22 AM, John C. Tull <john.tull at wildnevada.org> wrote:
> On Feb 5, 2009, at 2:51 PM, Martin Dobias wrote:
>> Hi all,
>> I'm happy to announce on the behalf of our qgis-mapper team a new
>> attribute table implementation for Quantum GIS. For those impatient,
>> the source is available here:
>> http://mapserver.sk/~wonder/qgis/beata-snapshot-090502.tar.gz
>> To install it, copy it to your svn trunk (1.0.0 source should be fine
>> too) into src/plugins/ directory. Then just edit
>> src/plugins/CMakeLists.txt, add there directory "beata" and that's it
>> - just compile and run!
>> The new implementation (called beata - short for better attribute
>> table) features:
>> - using Qt model/view design
>> - faster startup - the model fetches only features in the window
>> - fallback model that caches everything in memory (for layer that
>> don't support random access)
>> - cursor in table independent from currently selected row
>> - better usage of available space
>> We'll be happy to hear some feedback from you!
>> I hope there will be enough interest to put the plugin into SVN, and
>> in case that everyone's confident with new implementation, it could
>> replace the current implementation.
> Martin,
> On OS X from most current svn (10113), I have this problem:
> [ 83%] Building CXX object
> src/plugins/beata/CMakeFiles/beataplugin.dir/qrc_beata.o
> Linking CXX shared module libbeataplugin.so
> Undefined symbols:
> "QgsSearchQueryBuilder::searchString()", referenced from:
> BeataDialog::advancedSearch() in BeataDialog.o
> "QgisApp::editCopy(QgsMapLayer*)", referenced from:
> BeataDialog::copySelectedRowsToClipboard() in BeataDialog.o
> "QgsSearchQueryBuilder::QgsSearchQueryBuilder(QgsVectorLayer*, QWidget*,
> QFlags<Qt::WindowType>)", referenced from:
> "QgsSearchQueryBuilder::~QgsSearchQueryBuilder()", referenced from:
> "QgsSearchQueryBuilder::setSearchString(QString)", referenced from:
> "QgisApp::zoomToSelected()", referenced from:
> BeataDialog::zoomMapToSelectedRows() in BeataDialog.o
> "QgisApp::smInstance", referenced from:
> __ZN7QgisApp10smInstanceE$non_lazy_ptr in BeataDialog.o
> ld: symbol(s) not found
> collect2: ld returned 1 exit status
> make[2]: *** [src/plugins/beata/libbeataplugin.so] Error 1
> make[1]: *** [src/plugins/beata/CMakeFiles/beataplugin.dir/all] Error 2
> make[1]: *** Waiting for unfinished jobs....
Uhm... linking problems... I see the possible reason, we'll try to
address these problems soon.
Martin
