[Qgis-developer] Unable to import qgis.core on OS X
Luca Mandolesi
mandoluca at gmail.com
Sat Feb 7 11:40:23 EST 2009
> Are you using the python.org Python on Leopard, instead of the the system
>> Python?
> If you use the python.org Python on Leopard, you must use the Tiger Qgis.
I use Python.org, so I understand that it's correct if I use Tiger Qgis
I don't know about this one. Was this before or after my relink update?
> Does it work with the Tiger Qgis?
The problem was present before and don't work with any version.
I've realized a plugin and I want to separate alls my scripts into
subfolders; so I must to add the path in sys,path, and to maintain a cross
platform characteristic, I call sys.argv to pass the name of qgis path under
mac os, windows or linux. But sys.argv isn't present.
I asked about this on it.comp.lang.python list, but no one can help me.
Bye bye and thanks a lot
luca
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090207/20e9e240/attachment-0001.html
