[Qgis-developer] qgismapcomposer questions
massimo di stefano
massimodisasha at yahoo.it
Thu Feb 19 09:02:43 EST 2009
i haven't a long experience using the qgis mapcomposer,
so apologize me if my questions are bad formulated,
the mapcomposer in the last time had a great enanchments cool!
.... but i've some problems (maybe related to my platform OSX)
specially :
1 - tring to print a map in pdf using A4, all works as aspected
while changing the map dimension to A3 or other size ... it
print a "truncated map"
using "save as image" i haven't problems, it respect the size
and resoluction i chosed.
see :
2 - How can i reset the map composer ?
if i've a qgis project file .qgs , open it
try to print a map ... then close qgis, reopening the
mapcomposer
i can see that it don't start from an empty canvas ... so :
how can i reset it, to use a fresh composer in the qgs file i
saved ?
(simply : "don't save the project if you used mapcomposer
first ???")
thanks for any help,
Massimo
Massimo Di Stefano
epifanio on irc.freenode.net /join gfoss
strk - sorry i'm not able to delete the automatic footer :-(
Chiacchiera con i tuoi amici in tempo reale!
http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
