[Qgis-developer] New Plugin builder
Gary Sherman
sherman at mrcc.com
Sat Feb 21 17:30:12 EST 2009
I have created a web-based tool to build a minimal QGIS Python plugin.
Basically you specify the required parameters and it creates a ready
to run plugin with an blank dialog. The tool compiles the resource and
Ui files and packages it all up into a zip file for download.
You can try the builder at: http://pyqgis.org/builder/plugin_builder.py
The zip file contains a Makefile which can be used to recompile the Ui
and resource files if you change them. The builder uses Qt 4.4,
however the generated plugin should work on any QGIS 1.0 install.
If you've been wanting to develop QGIS plugins but didn't know where
to start, this tool can get you started quickly by setting up the
structure for you.
Comments and suggestions are welcomed.
-gary
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Chair, QGIS Project Steering Committee
-Micro Resources: http://mrcc.com
*Geospatial Hosting
*Web Site Hosting
-Desktop GIS Book:
*http://desktopgisbook.com
"We work virtually everywhere"
