[Qgis-developer] New Plugin builder
Barry Rowlingson b.rowlingson at lancaster.ac.uk
Sat Feb 21 18:09:26 EST 2009
2009/2/21 Gary Sherman <sherman at mrcc.com>:
> You can try the builder at: http://pyqgis.org/builder/plugin_builder.py
> The zip file contains a Makefile which can be used to recompile the Ui and
> resource files if you change them. The builder uses Qt 4.4, however the
> generated plugin should work on any QGIS 1.0 install.
My zip file didn't have a Makefile with it...
http://pyqgis.org/built_plugins/fnord.zip
Also, the fnordDialog.py file still has a comment relating to 'Zoom to
point' in it, which I guess is a hangover from your template plugin.
Needs substituting with the string from the web form.
Neat though.
Barry
