[Qgis-developer] new generation symbology
John C. Tull
john.tull at wildnevada.org
Sun Jan 4 13:18:25 EST 2009
Martin,
This sounds like a great project. I've installed the plugin using a
debug build of the latest svn code from trunk on OS X.
When I click on the paint palette icon, I get a window that has a
purple background and a button in the upper left that says "set
renderer", but nothing is rendered in that window. I am using a line
layer with road information that is rendered fine in the map canvas.
Is that correct (it sounds like the layer should render in the window).
Once I change settings from the set renderer window, I see no way to
apply these changes. Again, there is only one button in the renderer
window. It appears that the gui is not displaying correctly on my
system. I notice this message repeatedly in the Console, if it helps:
1/4/09 9:55:54 AM [0x0-0x29d29d].org.qgis.qgis[37347] FOOK
I made a debug build, and this time it crashed when I tried the plugin
with the following dump to the Console:
1/4/09 10:15:48 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
QPainter::begin: Cannot paint on a null pixmap
QPainter::setRenderHint: Painter must be active to set rendering hints
QPainter::end: Painter not active, aborted
1/4/09 10:15:59 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
1/4/09 10:16:01 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
1/4/09 10:16:02 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
1/4/09 10:16:04 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
Throwing exception /Users/jctull/sources/qgis/trunk/src/core/
qgscoordinatetransform.cpp503
qgscoordinatetransform.cpp226
qgscoordinatetransform.cpp246
Transform error caught in /Users/jctull/sources/qgis/trunk/src/core/
qgsmaprenderer.cpp, line 543
1/4/09 10:16:05 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
1/4/09 10:16:06 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
1/4/09 10:16:08 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
1/4/09 10:16:09 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
1/4/09 10:16:18 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
1/4/09 10:16:23 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
1/4/09 10:16:24 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
1/4/09 10:16:26 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
1/4/09 10:16:30 AM [0x0-0x2a22a2].org.qgis.qgis[43880] Warning:
And this was the crash log:
ess: qgis [43880]
Path: /Applications/qgis1.1.0.app/Contents/MacOS/qgis
Identifier: org.qgis.qgis
Version: 1.1.0-Unstable-trunk (9924M) (1.1.0-Unstable-trunk
(9924M))
Code Type: X86 (Native)
Parent Process: launchd [474]
Date/Time: 2009-01-04 10:16:36.941 -0800
OS Version: Mac OS X 10.5.6 (9G55)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000040
Crashed Thread: 0
Thread 0 Crashed:
0 libqgis_core.1.1.dylib 0x1461aa16 QgsMapLayer::type()
const + 6
1 core.so 0x14509871 sipSubClass_QgsMapLayer
+ 77
2 sip.so 0x02f395c1 convertSubClass + 138
3 sip.so 0x02f3dede
sip_api_convert_from_instance + 68
4 gui.so 0x14846c03
meth_QgsMapCanvas_currentLayer + 167
5 org.python.python 0x13928806 PyEval_EvalFrameEx + 17116
6 org.python.python 0x1392a45b PyEval_EvalCodeEx + 1638
7 org.python.python 0x138d4c27 PyFunction_SetClosure +
2646
8 org.python.python 0x138bad3d PyObject_Call + 50
9 org.python.python 0x138c35f8 PyMethod_New + 2457
10 org.python.python 0x138bad3d PyObject_Call + 50
11 org.python.python 0x13923b15
PyEval_CallObjectWithKeywords + 211
12 sip.so 0x02f4151f sip_api_invoke_slot + 410
13 QtCore.so 0x139cf4ef
PyQtProxy::invokeSlot(_sipSlotConnection const&, void**) + 117
14 QtCore.so 0x139dcdaa
PyQtProxy::unislot(void**) + 134
15 QtCore.so 0x139df62e
PyQtProxy::qt_metacall(QMetaObject::Call, int, void**) + 242
16 QtCore 0x005bc420
QMetaObject::activate(QObject*, int, int, void**) + 528
17 QtGui 0x009c5c0c QAction::triggered(bool)
+ 76
18 QtGui 0x009c778f
QAction::activate(QAction::ActionEvent) + 159
19 QtGui 0x00e17bb6
QToolButton::nextCheckState() + 38
20 QtGui 0x00d476ba
QAbstractButtonPrivate::click() + 74
21 QtGui 0x00d47940
QAbstractButton::mouseReleaseEvent(QMouseEvent*) + 128
22 QtGui 0x00e17afc
QToolButton::mouseReleaseEvent(QMouseEvent*) + 28
23 QtGui 0x00a14978 QWidget::event(QEvent*)
+ 3736
24 QtGui 0x00d48103
QAbstractButton::event(QEvent*) + 83
25 QtGui 0x00e17938
QToolButton::event(QEvent*) + 24
26 QtGui 0x009ccc1f
QApplicationPrivate::notify_helper(QObject*, QEvent*) + 191
27 QtGui 0x009ced4d
QApplication::notify(QObject*, QEvent*) + 1309
28 libqgis_core.1.1.dylib 0x002d5efb
QgsApplication::notify(QObject*, QEvent*) + 43
29 QtCore 0x005aad01
QCoreApplication::notifyInternal(QObject*, QEvent*) + 145
30 QtGui 0x00a2571b
QApplicationPrivate::globalEventProcessor(OpaqueEventHandlerCallRef*,
OpaqueEventRef*, void*) + 5771
31 com.apple.HIToolbox 0x90ba3143
DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*,
HandlerCallRec*) + 1181
32 com.apple.HIToolbox 0x90ba257d
SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*,
HandlerCallRec*) + 405
33 com.apple.HIToolbox 0x90bbeed2 SendEventToEventTarget +
52
34 com.apple.HIToolbox 0x90bd10a8
ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*,
OpaqueEventRef*, void*) + 1208
35 com.apple.HIToolbox 0x90ba34fc
HandlerCallRec*) + 2134
36 com.apple.HIToolbox 0x90ba257d
37 com.apple.HIToolbox 0x90bbeed2 SendEventToEventTarget +
52
38 QtGui 0x00a20521
qt_mac_send_event(QFlags<QEventLoop::ProcessEventsFlag>,
OpaqueEventRef*, OpaqueWindowPtr*) + 97
39 QtGui 0x00a2eb62
QEventDispatcherMac
::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 658
40 QtCore 0x005aa2c1
QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 65
41 QtCore 0x005aa38d
QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 157
42 QtCore 0x005ae331 QCoreApplication::exec()
+ 161
43 org.qgis.qgis 0x000092d5 main + 5909
44 org.qgis.qgis 0x00007006 start + 54
Thread 1:
0 libSystem.B.dylib 0x93b7d30a select$DARWIN_EXTSN
$NOCANCEL + 10
1 QtCore 0x0058dd2b QProcessManager::run() +
123
2 QtCore 0x004bf04b
QThreadPrivate::start(void*) + 203
3 libSystem.B.dylib 0x93b77095 _pthread_start + 321
4 libSystem.B.dylib 0x93b76f52 thread_start + 34
Thread 2:
0 libSystem.B.dylib 0x93b956f2 select$DARWIN_EXTSN + 10
1 libSystem.B.dylib 0x93b77095 _pthread_start + 321
2 libSystem.B.dylib 0x93b76f52 thread_start + 34
Thread 3:
0 libSystem.B.dylib 0x93b4620e
semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x93b78206 _pthread_cond_wait + 1267
2 libSystem.B.dylib 0x93bbd539 pthread_cond_wait + 48
3 QtCore 0x004c0446
QWaitCondition::wait(QMutex*, unsigned long) + 278
4 QtNetwork 0x01420e94 QHostInfoAgent::run() +
548
5 QtCore 0x004bf04b
6 libSystem.B.dylib 0x93b77095 _pthread_start + 321
7 libSystem.B.dylib 0x93b76f52 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x1450983f ecx: 0x003c1325 edx: 0x00000000
edi: 0x14430570 esi: 0x00000000 ebp: 0xbfffde28 esp: 0xbfffde28
ss: 0x0000001f efl: 0x00010286 eip: 0x1461aa16 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000040
Binary Images:
0x1000 - 0x1caff7 +org.qgis.qgis 1.1.0-Unstable-trunk (9924M)
(1.1.0-Unstable-trunk (9924M)) <e3bf3f3349182ca1d68b7b211e3d2266> /
0x270000 - 0x2aafe2 +libqgis_gui.1.1.dylib ??? (???)
<f9c89723a4c16d62ed3a457edacefe24> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/libqgis_gui.1.1.dylib
0x2d1000 - 0x422fff +libqgis_core.1.1.dylib ??? (???)
<eb2de6c1f00cc75ea457da109d4fc705> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/libqgis_core.1.1.dylib
0x4ab000 - 0x66aff3 +QtCore ??? (???)
<65af812e4c32f4801477de8395f94a35> /Library/Frameworks/
QtCore.framework/Versions/4/QtCore
0x6eb000 - 0x739fff +QtXml ??? (???)
<2baef6903a679b1c106ba1dded9761b8> /Library/Frameworks/QtXml.framework/
Versions/4/QtXml
0x9bb000 - 0x1115fff +QtGui ??? (???)
<3455418367b1d969f5739d03e8a0d09f> /Library/Frameworks/QtGui.framework/
Versions/4/QtGui
0x1376000 - 0x13b3ff5 +QtSvg ??? (???)
<33a9eba4f85d9604eeb92a296b2d3cae> /Library/Frameworks/QtSvg.framework/
Versions/4/QtSvg
0x13d1000 - 0x149bff2 +QtNetwork ??? (???)
<6a0e9f5576bd7774bfe9b182071e4a20> /Library/Frameworks/
QtNetwork.framework/Versions/4/QtNetwork
0x14e8000 - 0x1512fed +QtSql ??? (???)
<41e49b74a62c5b7517cb52db6651b0b8> /Library/Frameworks/QtSql.framework/
Versions/4/QtSql
0x1529000 - 0x1544ff3 +libpq.5.dylib ??? (???)
<2fccca6865119d04438211ce773a81e8> /usr/local/pgsql/lib/libpq.5.dylib
0x154e000 - 0x157afff +org.maptools.proj 4.6.1 (PROJ 4.6.1-2)
<0dc6b34895c8977b4291a5a076eb7cd3> /Library/Frameworks/PROJ.framework/
Versions/4.6/PROJ
0x1587000 - 0x163cffb +org.osgeo.geos 3.0.3 (GEOS 3.0.3-1)
<68a9068679ecab84cd200e603f9128ff> /Library/Frameworks/GEOS.framework/
Versions/3/GEOS
0x16ee000 - 0x215cfe2 +org.gdal.gdal 1.6.0 (GDAL/OGR 1.6.0-3)
<719e6b62284d38bdbca167d1c0d4f734> /Library/Frameworks/GDAL.framework/
Versions/1.6/GDAL
0x268d000 - 0x2720fe3 +org.sqlite.sqlite3 3.6.6.2 (SQLite3
3.6.6.2-1) <0a7f60797f4e8c49efea2288b9d599f7> /Library/Frameworks/
SQLite3.framework/Versions/3/SQLite3
0x2734000 - 0x273bfed +libgcc_s.1.dylib ??? (???) /usr/local/lib/
libgcc_s.1.dylib
0x275e000 - 0x279dfff libiodbc.2.dylib ??? (???)
<0e9f71de7fa6cfc5d42a7754d393b22c> /usr/lib/libiodbc.2.dylib
0x27ac000 - 0x27b9fff libiodbcinst.2.dylib ??? (???)
<f225b96d6bf1d05acdf0208a4ea3eebe> /usr/lib/libiodbcinst.2.dylib
0x27c0000 - 0x287ffe3 +com.kyngchaos.UnixImageIO 1.0.25
(UnixImageIO 1.0.25) <e0c10fef539e344cc4e4422920b28c32> /Library/
Frameworks/UnixImageIO.framework/Versions/B/UnixImageIO
0x28a5000 - 0x28d7fef +libogdi.dylib ??? (???)
<de574546caf58f6f9d48237419dd4f5d> /Library/Frameworks/GDAL.framework/
Versions/1.6/Libraries/libogdi.dylib
0x28e3000 - 0x290effb libcurl.4.dylib ??? (???)
<54ada27deb3b4ff7043d8836264eca0d> /usr/lib/libcurl.4.dylib
0x294e000 - 0x2955fff +libqgif.dylib ??? (???)
<6b830b2a8c7e241d18f1c9f477456a46> /Developer/Applications/Qt/plugins/
imageformats/libqgif.dylib
0x295a000 - 0x2961fff +libqico.dylib ??? (???)
<729e8abdf7d816234d08f70046d09da1> /Developer/Applications/Qt/plugins/
imageformats/libqico.dylib
0x2967000 - 0x2988fe3 +libqjpeg.dylib ??? (???)
<776330a7212b4fe872ecddc97cbec8e4> /Developer/Applications/Qt/plugins/
imageformats/libqjpeg.dylib
0x2990000 - 0x29d8fe7 +libqmng.dylib ??? (???)
<f3df0488b9511919668cb99a1b580de8> /Developer/Applications/Qt/plugins/
imageformats/libqmng.dylib
0x29e8000 - 0x29eefff +libqsvg.dylib ??? (???)
<f769373890dbb8c26fba83afe62870b8> /Developer/Applications/Qt/plugins/
imageformats/libqsvg.dylib
0x2b00000 - 0x2b49ff7 +libqtiff.dylib ??? (???)
<39ea970e3a5584e0b829bff7913d64c5> /Developer/Applications/Qt/plugins/
imageformats/libqtiff.dylib
0x2b5d000 - 0x2b5dffe +org.xlife.InquisitorLoader 3.2 (58)
<e4877ee4582562d98c95d447c8f77397> /Library/InputManagers/Inquisitor/
Inquisitor.bundle/Contents/MacOS/Inquisitor
0x2b62000 - 0x2b63ffd +com.machangout.Glims ??? (1.0)
<15cae0f8c7c25a3d56fd51414a1768f3> /Library/InputManagers/Glims/
Glims.bundle/Contents/MacOS/Glims
0x2b93000 - 0x2b95fff +net.culater.SIMBL 0.8.2 (8) /Library/
InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL
0x2ca7000 - 0x2ccbfff +libqtaccessiblewidgets.dylib ??? (???)
<8977ab4a16cb2284e050754c2116ff58> /Developer/Applications/Qt/plugins/
accessible/libqtaccessiblewidgets.dylib
0x2df7000 - 0x2e02fff +libcoordinatecaptureplugin.so ??? (???)
<21eca7b2f76146ba06d5b314e20d3939> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libcoordinatecaptureplugin.so
0x2e0a000 - 0x2e15fe7 +libcopyrightlabelplugin.so ??? (???)
<4fec32fecca7c906e883308d0ed26701> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libcopyrightlabelplugin.so
0x2e1d000 - 0x2e2afe5 +libdelimitedtextplugin.so ??? (???)
<70d089e0fbe6a9ebe0920a7e8882cc21> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libdelimitedtextplugin.so
0x2e33000 - 0x2e3dfe5 +libdelimitedtextprovider.so ??? (???)
<7d2ea5fefc2f5d091611f9d347c30a8a> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libdelimitedtextprovider.so
0x2e43000 - 0x2e71ff7 +libdxf2shpconverterplugin.so ??? (???)
<7b6f8b8fa2fa4ac64c12cb6f224eda9d> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libdxf2shpconverterplugin.so
0x2e7e000 - 0x2e8aff7 +libgrass_dig2.dylib ??? (???)
<0ab26385018dbeb556e3766761449296> /Applications/GRASS-6.4.app/
Contents/MacOS/lib/libgrass_dig2.dylib
0x2e90000 - 0x2e94ffd +libgrass_dbmiclient.dylib ??? (???)
<5a27d229e1d0cffdcb2d1bf142ca38f9> /Applications/GRASS-6.4.app/
Contents/MacOS/lib/libgrass_dbmiclient.dylib
0x2e9a000 - 0x2e9affc +libgrass_linkm.dylib ??? (???)
<6a2b00381f290538e8c4580741ea07b3> /Applications/GRASS-6.4.app/
Contents/MacOS/lib/libgrass_linkm.dylib
0x2e9e000 - 0x2eabff4 +libqgispython.dylib ??? (???)
<62fe7654909c80293af10475d642a279> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/libqgispython.dylib
0x2f37000 - 0x2f42ffd +sip.so ??? (???)
<8604f5c60f2f9275f307dd280b4d45d9> /Library/Python/2.5/site-packages/
sip.so
0x2f49000 - 0x2f4ffff +libgrass_dbmibase.dylib ??? (???)
<6f18b4ee9fb43ace99ddb78d31f77810> /Applications/GRASS-6.4.app/
Contents/MacOS/lib/libgrass_dbmibase.dylib
0x2f6c000 - 0x2f7efff libTraditionalChineseConverter.dylib ???
(???) <89ec94121ef50601dc538548caae57fc> /System/Library/CoreServices/
Encodings/libTraditionalChineseConverter.dylib
0x2f82000 - 0x2f90feb libSimplifiedChineseConverter.dylib ???
(???) <548d5a699dbe2bb8fcc8275321fdc0d4> /System/Library/CoreServices/
Encodings/libSimplifiedChineseConverter.dylib
0xc75a000 - 0xc75ffff com.apple.DictionaryServiceComponent 1.1
(1.1) <8edc1180f52db18e9ddfb4e95debe61b> /System/Library/Components/
DictionaryService.component/Contents/MacOS/DictionaryService
0xc766000 - 0xc785fff +libgeorefplugin.so ??? (???)
<3d4e0af5aa45a0e8fd45dcc57cc15aac> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libgeorefplugin.so
0xc796000 - 0xc797fff +libgrass_form.dylib ??? (???)
<6da7b4cb64922e6ff7370f48471249c4> /Applications/GRASS-6.4.app/
Contents/MacOS/lib/libgrass_form.dylib
0xe785000 - 0xe78bfff +libgrass_shape.dylib ??? (???)
<1b74b86dc7b46d899c2369d797282146> /Applications/GRASS-6.4.app/
Contents/MacOS/lib/libgrass_shape.dylib
0xe78f000 - 0xe792fff +libgrass_rtree.dylib ??? (???)
<3ed499f19fa9a2994c3d161758eae815> /Applications/GRASS-6.4.app/
Contents/MacOS/lib/libgrass_rtree.dylib
0xe7ad000 - 0xe7b8ffb +com.fsb.SafariBlock ??? (2.1) /Library/
InputManagers/SafariBlock/SafariBlock.bundle/Contents/MacOS/SafariBlock
0x10114000 - 0x10122ffc +libgrass_dgl.dylib ??? (???)
<31d2cab60b239c2b82a13740ebc1df95> /Applications/GRASS-6.4.app/
Contents/MacOS/lib/libgrass_dgl.dylib
0x109de000 - 0x10a4bfff +com.DivXInc.DivXDecoder 6.6.0 (6.6.0) /
Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
0x10a5a000 - 0x10a73ffb +libgpxprovider.so ??? (???)
<492e72a60a5b9bcca6cdf6c7e58d75d3> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libgpxprovider.so
0x10a7e000 - 0x10a82fff +libgrass_datetime.dylib ??? (???)
<567fd16544440d7876fdd3d33c528dc8> /Applications/GRASS-6.4.app/
Contents/MacOS/lib/libgrass_datetime.dylib
0x11f3c000 - 0x11f88fff +libgslcblas.0.dylib ??? (???) /usr/local/lib/
libgslcblas.0.dylib
0x11f8d000 - 0x11fbdff3 +libgpsimporterplugin.so ??? (???)
<e3063a1b88ddb69e3c498cf45d087326> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libgpsimporterplugin.so
0x11fcf000 - 0x11fd4fff +libgrass_gproj.dylib ??? (???)
<e02abc0b2d4e292dcbdc8601a8df36d2> /Applications/GRASS-6.4.app/
Contents/MacOS/lib/libgrass_gproj.dylib
0x11fd9000 - 0x11fe0fff +libgrassprovider.so ??? (???)
<fd97b144e2ed9ff1c48ab17989584c98> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libgrassprovider.so
0x12136000 - 0x12154fe3 libexpat.1.dylib ??? (???)
<eff8a63a23a7d07af62b36fdb329e393> /usr/lib/libexpat.1.dylib
0x1215c000 - 0x1217dfff +libqgisgrass.1.1.dylib ??? (???)
<0549a53234ced6da67e269604039bd4d> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/libqgisgrass.1.1.dylib
0x1218b000 - 0x121c1fe7 +libgrass_gis.dylib ??? (???)
<60956b2c3b4237c8e271cfe7c8c628c6> /Applications/GRASS-6.4.app/
Contents/MacOS/lib/libgrass_gis.dylib
0x121d2000 - 0x121fbff7 +libgrass_vect.dylib ??? (???)
<48a09352b17df100a2f3fd5de0b8669b> /Applications/GRASS-6.4.app/
Contents/MacOS/lib/libgrass_vect.dylib
0x12207000 - 0x1220eff7 +libmemoryprovider.so ??? (???)
<143ba8fb425d8f9344672b557a437866> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libmemoryprovider.so
0x1263f000 - 0x1264fff7 +libgridmakerplugin.so ??? (???)
<bea3230b5fefff07013e375d72e01283> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libgridmakerplugin.so
0x12658000 - 0x12679ffb +libinterpolationplugin.so ??? (???)
<b00a16966b935ae0e75c6179c18b93e9> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libinterpolationplugin.so
0x12687000 - 0x12693ff7 +libnortharrowplugin.so ??? (???)
<0a2d1d0aaa9f9fcc7ad683d0dd7f630e> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libnortharrowplugin.so
0x1269c000 - 0x126afff3 +libogrconverterplugin.so ??? (???)
<4f87e83b80783efbaa29d919b05adaaf> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libogrconverterplugin.so
0x126b9000 - 0x126c6ff7 +libogrprovider.so ??? (???)
<ddd66a620477cb6d585a000e95fb2398> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libogrprovider.so
0x126ce000 - 0x126d3fff +ogr_GRASS.dylib ??? (???)
<381309ebbd7a7e5c8908a06c928d0f50> /Library/Frameworks/GDAL.framework/
Versions/1.6/PlugIns/ogr_GRASS.dylib
0x126d9000 - 0x126deffb +libgrass_I.dylib ??? (???)
<af1b999455fe9048c8b97af30406fa39> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_I.dylib
0x126e3000 - 0x126e5ffc +libgrass_vask.dylib ??? (???)
<a730393ae51fe4904008d045bed411f4> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_vask.dylib
0x126ea000 - 0x126edff7 +libgrass_gmath.dylib ??? (???)
<abc7c5abb893c4573c6b885c8998998e> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_gmath.dylib
0x126f1000 - 0x126f5fff +libgrass_datetime.dylib ??? (???)
<bd0bb46b4b52f39d497fb3385f92e662> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_datetime.dylib
0x126f9000 - 0x126fcfff +libgrass_rtree.dylib ??? (???)
<0a770ddbdb1abfe17744040eb8cf5b7d> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_rtree.dylib
0x128fe000 - 0x12af5fee +com.elgato.mpegsupport EyeTV MPEG Support
1.0.9 (build 46) (1.0.9) /Library/QuickTime/EyeTV MPEG
Support.component/Contents/MacOS/EyeTV MPEG Support
0x12d61000 - 0x12f5efef +libgsl.0.dylib ??? (???) /usr/local/lib/
libgsl.0.dylib
0x12faf000 - 0x130f0ffd +libgrassplugin.so ??? (???)
<c905e8acd7dfe0bc42e28577d4a9f490> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libgrassplugin.so
0x1313f000 - 0x13349fff +Qt3Support ??? (???)
<bbb0a882710f6706fa4b9a2123ed9ab5> /Library/Frameworks/
Qt3Support.framework/Versions/4/Qt3Support
0x13429000 - 0x1345ffe7 +libgrass_gis.dylib ??? (???)
<c20844e88aa0dba83d66f73bb953567f> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_gis.dylib
0x13470000 - 0x13475fff +libgrass_gproj.dylib ??? (???)
<c66ef8b77ebc1e18805f89ef5b24fdad> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_gproj.dylib
0x1347a000 - 0x134a3ff7 +libgrass_vect.dylib ??? (???)
<ed52d835a896305759d3c469dcc409b2> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_vect.dylib
0x134af000 - 0x134b5fff +libgrass_dbmibase.dylib ??? (???)
<3a1cb22cc9353c77b773f58f57a1b305> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_dbmibase.dylib
0x134bc000 - 0x134c0ffd +libgrass_dbmiclient.dylib ??? (???)
<f1ef8df77837dcae3d75f94daa731e62> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_dbmiclient.dylib
0x134c6000 - 0x134d2ff7 +libgrass_dig2.dylib ??? (???)
<26831fe01b3f092530f0f318ec68af6e> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_dig2.dylib
0x134d8000 - 0x134e6ffc +libgrass_dgl.dylib ??? (???)
<c3d2ce33e39158ac2e850757b6779354> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_dgl.dylib
0x134ed000 - 0x134edffc +libgrass_linkm.dylib ??? (???)
<40fe362226994797387bb3cecf9ced41> /Library/Frameworks/GDAL.framework/
Versions/1.6/grass/lib/libgrass_linkm.dylib
0x134f1000 - 0x13521ff3 +libpostgresprovider.so ??? (???)
<3de29c1853d09c458bdf73798f370cbf> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libpostgresprovider.so
0x13532000 - 0x1353eff7 +libquickprintplugin.so ??? (???)
<a13e362d3336cc9c36304d66946ed354> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libquickprintplugin.so
0x13546000 - 0x13553fef +libscalebarplugin.so ??? (???)
<93c8180b81fc55da5aaa5813cf48ff9d> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libscalebarplugin.so
0x1355b000 - 0x13585ff1 +libspitplugin.so ??? (???)
<4e2658cdea60946a046cbb0f8ebdff26> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libspitplugin.so
0x13598000 - 0x135a7fe9 +libwfsplugin.so ??? (???)
<09eb898283fc4c80c9dc0f31cf79e972> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libwfsplugin.so
0x135b1000 - 0x135c9ffa +libwfsprovider.so ??? (???)
<8564f77e38234765c62152fc53ef9660> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libwfsprovider.so
0x135d4000 - 0x13603ff9 +libwmsprovider.so ??? (???)
<79af97c33e0e0a2dad8900a9cf56f2c0> /Applications/qgis1.1.0.app/
Contents/MacOS/lib/qgis/libwmsprovider.so
0x13616000 - 0x13618ffe itertools.so ??? (???)
<3db795c34c2ce8361e511ba620004d01> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/itertools.so
0x1361d000 - 0x1361efff collections.so ??? (???)
<a63cd2a91e1a4885fd46cd2a3b08edb4> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/collections.so
0x13736000 - 0x13738ffd strop.so ??? (???)
<90360a83b2f7bb7ac308305ec9d1d72b> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/strop.so
0x13749000 - 0x1374afff time.so ??? (???)
<868136633e00f35cc39fbefc508644bb> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/time.so
0x13758000 - 0x1375affb _struct.so ??? (???)
<8b8f6554c96be9fdef4d31ba4296238f> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/_struct.so
0x1375e000 - 0x1375efff select.so ??? (???)
<fdd51d8c44078244791b73f51e525048> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/select.so
0x138b3000 - 0x1397efeb org.python.python 2.5 (2.5)
<e25c22d85c260b924b91ee8f643c0774> /System/Library/Frameworks/
Python.framework/Versions/2.5/Python
0x139cb000 - 0x13af8ffe +QtCore.so ??? (???)
<c33dfe4311432aa61f9ca1ca8d0e2810> /Library/Python/2.5/site-packages/
PyQt4/QtCore.so
0x13bb7000 - 0x140e1ffb +QtGui.so ??? (???)
<6a0c4f45bb52ecdbefd436aa924f8fb2> /Library/Python/2.5/site-packages/
PyQt4/QtGui.so
0x143e0000 - 0x143e1ffe binascii.so ??? (???)
<743904191cd46b07df2affa130d9d529> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/binascii.so
0x143e6000 - 0x143e7fff cStringIO.so ??? (???)
<193a853e31e48a248e091df545b7498a> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/cStringIO.so
0x143eb000 - 0x143edffd zlib.so ??? (???)
<d1088c15777bc475b50fb6a1f19e8ff4> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/zlib.so
0x14500000 - 0x1458bfff +core.so ??? (???)
<9dd8df2a402041aa42ad9ee0d8c68459> /Applications/qgis1.1.0.app/
Contents/MacOS/share/qgis/python/qgis/core.so
0x145e6000 - 0x14737fff +libqgis_core.1.1.dylib ??? (???)
<eb2de6c1f00cc75ea457da109d4fc705> /Users/jctull/sources/qgis/trunk/
build/src/core/libqgis_core.1.1.dylib
0x147c0000 - 0x147effff +QtXml.so ??? (???)
<aaf5f429aa54901582ded4012ecdf2da> /Library/Python/2.5/site-packages/
PyQt4/QtXml.so
0x1480e000 - 0x14877ffe +gui.so ??? (???)
<65a9a67028b2939a71c8d98e42244717> /Applications/qgis1.1.0.app/
Contents/MacOS/share/qgis/python/qgis/gui.so
0x148b5000 - 0x148effe2 +libqgis_gui.1.1.dylib ??? (???)
<f9c89723a4c16d62ed3a457edacefe24> /Users/jctull/sources/qgis/trunk/
build/src/gui/libqgis_gui.1.1.dylib
0x14996000 - 0x1499ffff datetime.so ??? (???)
<f9bdeb667ff921c532541d9257069b77> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/datetime.so
0x149ba000 - 0x149bbfff math.so ??? (???)
<b42064a20bcfa11c62d074349b45668f> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/math.so
0x14af4000 - 0x14af6fff _csv.so ??? (???)
<58bbaf8e334c3e20397e281c2bf187eb> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/_csv.so
0x14afb000 - 0x14afcfff _random.so ??? (???)
<07c722b3bf7042863171656855d61fd7> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/_random.so
0x14c3c000 - 0x14c3cffd fcntl.so ??? (???)
<d53657c5ef75a4a15efdb6d5dd711942> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/fcntl.so
0x14c80000 - 0x14cd0fff +QtNetwork.so ??? (???)
<5edb10a90960c0b166085b6b4e297d91> /Library/Python/2.5/site-packages/
PyQt4/QtNetwork.so
0x14d6d000 - 0x14d6dffe icglue.so ??? (???)
<6a30d88cb541d127c0d41bdf631664ab> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/icglue.so
0x14d71000 - 0x14d74ffe _Res.so ??? (???)
<8fabdb152a7aaf9ac8390134ac36cca4> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/_Res.so
0x14d79000 - 0x14d7ffff _File.so ??? (???)
<203ecf752c3ecbe05425a5b15f858e20> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/_File.so
0x14d8a000 - 0x14d8bfff MacOS.so ??? (???)
<a087e87affa104ada1893aeb88e74768> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/MacOS.so
0x14db4000 - 0x14dc8fff +QtSvg.so ??? (???)
<59516cff1a1ab51f39ec4fd66ee6c92b> /Library/Python/2.5/site-packages/
PyQt4/QtSvg.so
0x14dd7000 - 0x14dd9fff operator.so ??? (???)
<adf9306faf619ef7003876ad4989eb91> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/operator.so
0x14e5e000 - 0x14e63ffe _elementtree.so ??? (???)
<c74d9dca9edb7fdfc452a9affbcee7ce> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/_elementtree.so
0x14ee7000 - 0x14eeaffd array.so ??? (???)
<6ab66b64c9e01baccae0d04d8e623c6c> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/array.so
0x14eef000 - 0x14ef4ffe pyexpat.so ??? (???)
<52f3a0407a2af249151826f21595089e> /System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-dynload/pyexpat.so
0x14ff3000 - 0x14ff6ffb +gdal_GRASS.dylib ??? (???)
<651a10126e0b79c08f8d41858643b40c> /Library/Frameworks/GDAL.framework/
Versions/1.6/PlugIns/gdal_GRASS.dylib
0x151a9000 - 0x1528cfef +gdal_ECW_JP2ECW.dylib ??? (???)
<7fca1e712c66eff6c5fbd31f2bbe0760> /Library/Application Support/GDAL/
1.6/PlugIns/gdal_ECW_JP2ECW.dylib
0x15318000 - 0x153cdff2 +gdal_MrSID.dylib ??? (???)
<2e50b0e40c72924cd74670046ea8e195> /Library/Application Support/GDAL/
1.6/PlugIns/gdal_MrSID.dylib
0x15dc8000 - 0x15fb0fff com.apple.RawCamera.bundle 2.0.11 (410)
<7704cc57f7daceb81672bfdc4434da40> /System/Library/CoreServices/
RawCamera.bundle/Contents/MacOS/RawCamera
0x8fe00000 - 0x8fe2db43 dyld 97.1 (???)
<100d362e03410f181a34e04e94189ae5> /usr/lib/dyld
0x9003a000 - 0x90049fff libsasl2.2.dylib ??? (???)
<bb7971ca2f609c070f87786a93d1041e> /usr/lib/libsasl2.2.dylib
0x9004a000 - 0x90065ffb libPng.dylib ??? (???)
<4780e979d35aa5ec2cea22678836cea5> /System/Library/Frameworks/
ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/
Versions/A/Resources/libPng.dylib
0x90066000 - 0x90476fef libBLAS.dylib ??? (???) /System/Library/
Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/
Versions/A/libBLAS.dylib
0x90477000 - 0x904d4ffb libstdc++.6.dylib ??? (???)
<04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
0x904d5000 - 0x907afff3 com.apple.CoreServices.CarbonCore 786.10
(786.10) <ec35bb05f67fe0e828d49dda88bbf6d7> /System/Library/Frameworks/
CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/
Versions/A/CarbonCore
0x907fa000 - 0x90897ffc com.apple.CFNetwork 422.11 (422.11)
<2780dfc3d2186195fccb3634bfb0944b> /System/Library/Frameworks/
CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/
Versions/A/CFNetwork
0x90898000 - 0x908c5feb libvDSP.dylib ??? (???)
<b232c018ddd040ec4e2c2af632dd497f> /System/Library/Frameworks/
Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/
libvDSP.dylib
0x908c6000 - 0x908fdfff com.apple.SystemConfiguration 1.9.2 (1.9.2)
<8b26ebf26a009a098484f1ed01ec499c> /System/Library/Frameworks/
SystemConfiguration.framework/Versions/A/SystemConfiguration
0x90933000 - 0x90984ff7 com.apple.HIServices 1.7.0 (???)
<01b690d1f376e400ac873105533e39eb> /System/Library/Frameworks/
HIServices.framework/Versions/A/HIServices
0x90b5c000 - 0x90b9aff7 libGLImage.dylib ??? (???)
<1123b8a48bcbe9cc7aa8dd8e1a214a66> /System/Library/Frameworks/
OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x90b9b000 - 0x90ea3fff com.apple.HIToolbox 1.5.4 (???)
<3747086ba21ee419708a5cab946c8ba6> /System/Library/Frameworks/
Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/
HIToolbox
0x90ea9000 - 0x90ecdfeb libssl.0.9.7.dylib ??? (???)
<c7359b7ab32b5f8574520746e10a41cc> /usr/lib/libssl.0.9.7.dylib
0x90ece000 - 0x90f75feb com.apple.QD 3.11.54 (???)
<b743398c24c38e581a86e91744a2ba6e> /System/Library/Frameworks/
ApplicationServices.framework/Versions/A/Frameworks/QD.framework/
Versions/A/QD
0x90fa1000 - 0x91028ff7 libsqlite3.0.dylib ??? (???)
<6978bbcca4277d6ae9f042beff643f7d> /usr/lib/libsqlite3.0.dylib
0x9113e000 - 0x91154fe7 com.apple.CoreVideo 1.5.1 (1.5.1)
<001910004257f1386724398f584b30b5> /System/Library/Frameworks/
CoreVideo.framework/Versions/A/CoreVideo
0x91155000 - 0x91477fe2 com.apple.QuickTime 7.5.5 (990.7)
<87077cec43c7e9b02c8ee80e50b8b81f> /System/Library/Frameworks/
QuickTime.framework/Versions/A/QuickTime
0x91478000 - 0x915caff3 com.apple.audio.toolbox.AudioToolbox 1.5.2
(1.5.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/
AudioToolbox
0x915cb000 - 0x915cbffa com.apple.CoreServices 32 (32)
<2fcc8f3bd5bbfc000b476cad8e6a3dd2> /System/Library/Frameworks/
CoreServices.framework/Versions/A/CoreServices
0x915cc000 - 0x92581ffe com.apple.QuickTimeComponents.component 7.5.5
(990.7) /System/Library/QuickTime/QuickTimeComponents.component/
Contents/MacOS/QuickTimeComponents
0x92582000 - 0x9291ffef com.apple.QuartzCore 1.5.7 (1.5.7)
<2fed2dd7565c84a0f0c608d41d4d172c> /System/Library/Frameworks/
QuartzCore.framework/Versions/A/QuartzCore
0x92920000 - 0x92948ff7 com.apple.shortcut 1 (1.0)
<057783867138902b52bc0941fedb74d1> /System/Library/PrivateFrameworks/
Shortcut.framework/Versions/A/Shortcut
0x9294a000 - 0x92984fe7 com.apple.coreui 1.2 (62) /System/Library/
PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x929ec000 - 0x92a78ff7 com.apple.LaunchServices 290.3 (290.3)
<6f9629f4ed1ba3bb313548e6838b2888> /System/Library/Frameworks/
CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/
Versions/A/LaunchServices
0x92a7a000 - 0x92a8affc com.apple.LangAnalysis 1.6.4 (1.6.4)
<8b7831b5f74a950a56cf2d22a2d436f6> /System/Library/Frameworks/
LangAnalysis.framework/Versions/A/LangAnalysis
0x92a8e000 - 0x92ad7fef com.apple.Metadata 10.5.2 (398.25)
<e0572f20350523116f23000676122a8d> /System/Library/Frameworks/
CoreServices.framework/Versions/A/Frameworks/Metadata.framework/
Versions/A/Metadata
0x92ad8000 - 0x92af7ffa libJPEG.dylib ??? (???)
<e7eb56555109e23144924cd64aa8daec> /System/Library/Frameworks/
Versions/A/Resources/libJPEG.dylib
0x92af8000 - 0x92b83fff com.apple.framework.IOKit 1.5.1 (???)
<f9f5f0d070e197a832d86751e1d44545> /System/Library/Frameworks/
IOKit.framework/Versions/A/IOKit
0x92b84000 - 0x92c01fef libvMisc.dylib ??? (???) /System/Library/
Versions/A/libvMisc.dylib
0x92c02000 - 0x930d3f3e libGLProgrammability.dylib ??? (???)
<5d283543ac844e7c6fa3440ac56cd265> /System/Library/Frameworks/
OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x93233000 - 0x93265fff com.apple.LDAPFramework 1.4.5 (110)
<cc04500cf7b6edccc75bb3fe2973f72c> /System/Library/Frameworks/
LDAP.framework/Versions/A/LDAP
0x93266000 - 0x932f9fff com.apple.ink.framework 101.3 (86)
<bf3fa8927b4b8baae92381a976fd2079> /System/Library/Frameworks/
Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9332d000 - 0x93335fff com.apple.DiskArbitration 2.2.1 (2.2.1)
<75b0c8d8940a8a27816961dddcac8e0f> /System/Library/Frameworks/
DiskArbitration.framework/Versions/A/DiskArbitration
0x93336000 - 0x9338fff7 libGLU.dylib ??? (???) /System/Library/
Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x93390000 - 0x93390ffb com.apple.installserver.framework 1.0 (8) /
System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/
InstallServer
0x93391000 - 0x93393ff5 libRadiance.dylib ??? (???)
<8a844202fcd65662bb9ab25f08c45a62> /System/Library/Frameworks/
Versions/A/Resources/libRadiance.dylib
0x93476000 - 0x93476ffd com.apple.Accelerate.vecLib 3.4.2 (vecLib
3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/
Frameworks/vecLib.framework/Versions/A/vecLib
0x93477000 - 0x93b17fff com.apple.CoreGraphics 1.407.2 (???)
<3a91d1037afde01d1d8acdf9cd1caa14> /System/Library/Frameworks/
CoreGraphics.framework/Versions/A/CoreGraphics
0x93b18000 - 0x93b18ff8 com.apple.Cocoa 6.5 (???)
<e064f94d969ce25cb7de3cfb980c3249> /System/Library/Frameworks/
Cocoa.framework/Versions/A/Cocoa
0x93b19000 - 0x93b44fe7 libauto.dylib ??? (???)
<42d8422dc23a18071869fdf7b5d8fab5> /usr/lib/libauto.dylib
0x93b45000 - 0x93cacff3 libSystem.B.dylib ??? (???)
<d68880dfb1f8becdbdac6928db1510fb> /usr/lib/libSystem.B.dylib
0x93d1b000 - 0x93d22ffe libbsm.dylib ??? (???)
<d25c63378a5029648ffd4b4669be31bf> /usr/lib/libbsm.dylib
0x93d23000 - 0x93d29fff com.apple.print.framework.Print 218.0.2
(220.1) <8bf7ef71216376d12fcd5ec17e43742c> /System/Library/Frameworks/
Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x93d7a000 - 0x93e2cffb libcrypto.0.9.7.dylib ??? (???)
<69bc2457aa23f12fa7d052601d48fa29> /usr/lib/libcrypto.0.9.7.dylib
0x9447f000 - 0x944a3fff libxslt.1.dylib ??? (???)
<0a9778d6368ae668826f446878deb99b> /usr/lib/libxslt.1.dylib
0x944a4000 - 0x944b0ffe libGL.dylib ??? (???) /System/Library/
Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x944b1000 - 0x945a5ff4 libiconv.2.dylib ??? (???)
<c508c60fafca17824c0017b2e4369802> /usr/lib/libiconv.2.dylib
0x94675000 - 0x94756ff7 libxml2.2.dylib ??? (???)
<d69560099d9eb32ba7f8a17baa65a28d> /usr/lib/libxml2.2.dylib
0x94757000 - 0x947d4feb com.apple.audio.CoreAudio 3.1.1 (3.1.1)
<f35477a5e23db0fa43233c37da01ae1c> /System/Library/Frameworks/
CoreAudio.framework/Versions/A/CoreAudio
0x947ed000 - 0x948cdfff libobjc.A.dylib ??? (???)
<7b92613fdf804fd9a0a3733a0674c30b> /usr/lib/libobjc.A.dylib
0x948ce000 - 0x948d8feb com.apple.audio.SoundManager 3.9.2 (3.9.2)
<0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/
Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/
A/CarbonSound
0x948d9000 - 0x9496cff3 com.apple.ApplicationServices.ATS 3.4 (???)
<8c51de0ec3deaef416578cd59df38754> /System/Library/Frameworks/
ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/
Versions/A/ATS
0x9496d000 - 0x94aa0fff com.apple.CoreFoundation 6.5.5 (476.17)
<4a70c8dbb582118e31412c53dc1f407f> /System/Library/Frameworks/
CoreFoundation.framework/Versions/A/CoreFoundation
0x94b22000 - 0x94b25fff com.apple.help 1.1 (36)
<b507b08e484cb89033e9cf23062d77de> /System/Library/Frameworks/
Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x94b26000 - 0x94b26ffd com.apple.Accelerate 1.4.2 (Accelerate
1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/
Accelerate
0x94b27000 - 0x94bb1fe3 com.apple.DesktopServices 1.4.7 (1.4.7)
<d16642ba22c32f67be793ebfbe67ca3a> /System/Library/PrivateFrameworks/
DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x94bb2000 - 0x94bb2ff8 com.apple.ApplicationServices 34 (34)
<8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/
ApplicationServices.framework/Versions/A/ApplicationServices
0x94bd1000 - 0x94bd3fff com.apple.securityhi 3.0 (30817)
<2b2854123fed609d1820d2779e2e0963> /System/Library/Frameworks/
Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/
SecurityHI
0x94bd4000 - 0x94be4fff com.apple.speech.synthesis.framework 3.7.1
(3.7.1) <06d8fc0307314f8ffc16f206ad3dbf44> /System/Library/Frameworks/
SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x94ca4000 - 0x94cfeff7 com.apple.CoreText 2.0.3 (???)
<1f1a97273753e6cfea86c810d6277680> /System/Library/Frameworks/
ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/
Versions/A/CoreText
0x94cff000 - 0x94d08fff com.apple.speech.recognition.framework 3.7.24
(3.7.24) <d3180f9edbd9a5e6f283d6156aa3c602> /System/Library/Frameworks/
Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/
Versions/A/SpeechRecognition
0x94d09000 - 0x94d38ff7 libncurses.5.4.dylib ??? (???)
<3b2ac2ca8190942b6b81d2a7012ea859> /usr/lib/libncurses.5.4.dylib
0x94d39000 - 0x94ddbff3 com.apple.QuickTimeImporters.component 7.5.5
(990.7) /System/Library/QuickTime/QuickTimeImporters.component/
Contents/MacOS/QuickTimeImporters
0x94e16000 - 0x94e55fef libTIFF.dylib ??? (???)
<3589442575ac77746ae99ecf724f5f87> /System/Library/Frameworks/
Versions/A/Resources/libTIFF.dylib
0x950bf000 - 0x95101fef com.apple.NavigationServices 3.5.2 (163)
<91844980804067b07a0b6124310d3f31> /System/Library/Frameworks/
Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/
Versions/A/NavigationServices
0x95194000 - 0x9524efe3 com.apple.CoreServices.OSServices 226.5
(226.5) <2a135d4fb16f4954290f7b72b4111aa3> /System/Library/Frameworks/
CoreServices.framework/Versions/A/Frameworks/OSServices.framework/
Versions/A/OSServices
0x95255000 - 0x9525cff7 libCGATS.A.dylib ??? (???)
<386dce4b28448fb86e33e06ac466f4d8> /System/Library/Frameworks/
CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x9525d000 - 0x95a5bfef com.apple.AppKit 6.5.6 (949.43)
<a3a300499bbe4f1dfebf71d752d01916> /System/Library/Frameworks/
AppKit.framework/Versions/C/AppKit
0x95a5c000 - 0x95b27fff com.apple.ColorSync 4.5.1 (4.5.1) /System/
Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/
ColorSync.framework/Versions/A/ColorSync
0x95b68000 - 0x95c2fff2 com.apple.vImage 3.0 (3.0) /System/Library/
Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/
Versions/A/vImage
0x95c30000 - 0x95c30ffd com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/
Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x95c31000 - 0x95d16ff3 com.apple.CoreData 100.1 (186)
<8e28162ef2288692615b52acc01f8b54> /System/Library/Frameworks/
CoreData.framework/Versions/A/CoreData
0x95d17000 - 0x960d5fea libLAPACK.dylib ??? (???) /System/Library/
Versions/A/libLAPACK.dylib
0x960d6000 - 0x96117fe7 libRIP.A.dylib ??? (???)
<5d0b5af7992e14de017f9a9c7cb05960> /System/Library/Frameworks/
CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x96118000 - 0x961c8fff edu.mit.Kerberos 6.0.12 (6.0.12)
<685cc018c133668d0d3ac6a1cb63cff9> /System/Library/Frameworks/
Kerberos.framework/Versions/A/Kerberos
0x961c9000 - 0x96444fe7 com.apple.Foundation 6.5.7 (677.22)
<8fe77b5d15ecdae1240b4cb604fc6d0b> /System/Library/Frameworks/
Foundation.framework/Versions/C/Foundation
0x9644a000 - 0x9644efff libGIF.dylib ??? (???)
<572a32e46e33be1ec041c5ef5b0341ae> /System/Library/Frameworks/
Versions/A/Resources/libGIF.dylib
0x9644f000 - 0x9647efe3 com.apple.AE 402.2 (402.2)
<e01596187e91af5d48653920017b8c8e> /System/Library/Frameworks/
CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9652e000 - 0x9652effc com.apple.audio.units.AudioUnit 1.5 (1.5) /
System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9652f000 - 0x9654dfff libresolv.9.dylib ??? (???)
<a8018c42930596593ddf27f7c20fe7af> /usr/lib/libresolv.9.dylib
0x9654e000 - 0x965aaff7 com.apple.htmlrendering 68 (1.1.3)
<fe87a9dede38db00e6c8949942c6bd4f> /System/Library/Frameworks/
Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/
Versions/A/HTMLRendering
0x965ab000 - 0x965b2fe9 libgcc_s.1.dylib ??? (???)
<f53c808e87d1184c0f9df63aef53ce0b> /usr/lib/libgcc_s.1.dylib
0x96725000 - 0x9673bfff com.apple.DictionaryServices 1.0.0 (1.0.0)
<ad0aa0252e3323d182e17f50defe56fc> /System/Library/Frameworks/
DictionaryServices.framework/Versions/A/DictionaryServices
0x9673c000 - 0x96743fff com.apple.agl 3.0.9 (AGL-3.0.9)
<2f39c480cfcee9358a23d61b20a6aa56> /System/Library/Frameworks/
AGL.framework/Versions/A/AGL
0x96744000 - 0x96745ffc libffi.dylib ??? (???)
<a3b573eb950ca583290f7b2b4c486d09> /usr/lib/libffi.dylib
0x96746000 - 0x9676efff libcups.2.dylib ??? (???)
<81abd305142ad1b771024eb4a1309e2e> /usr/lib/libcups.2.dylib
0x96779000 - 0x96779fff com.apple.Carbon 136 (136)
<98a5e3bc0c4fa44bbb09713bb88707fe> /System/Library/Frameworks/
Carbon.framework/Versions/A/Carbon
0x96a73000 - 0x96aedff8 com.apple.print.framework.PrintCore 5.5.3
(245.3) <222dade7b33b99708b8c09d1303f93fc> /System/Library/Frameworks/
PrintCore.framework/Versions/A/PrintCore
0x96aee000 - 0x96b06fff com.apple.openscripting 1.2.8 (???)
<572c7452d7e740e8948a5ad07a99602b> /System/Library/Frameworks/
Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/
Versions/A/OpenScripting
0x96b07000 - 0x96b14fe7 com.apple.opengl 1.5.9 (1.5.9)
<7e5048a2677b41098c84045305f42f7f> /System/Library/Frameworks/
OpenGL.framework/Versions/A/OpenGL
0x96b15000 - 0x96b21ff9 com.apple.helpdata 1.0.1 (14.2) /System/
Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x96b36000 - 0x96c7cff7 com.apple.ImageIO.framework 2.0.4 (2.0.4)
<6a6623d3d1a7292b5c3763dcd108b55f> /System/Library/Frameworks/
Versions/A/ImageIO
0x96c83000 - 0x96c98ffb com.apple.ImageCapture 5.0.1 (5.0.1) /System/
Library/Frameworks/Carbon.framework/Versions/A/Frameworks/
ImageCapture.framework/Versions/A/ImageCapture
0x96c99000 - 0x96c9efff com.apple.CommonPanels 1.2.4 (85)
<ea0665f57cd267609466ed8b2b20e893> /System/Library/Frameworks/
Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/
A/CommonPanels
0x96cab000 - 0x96de3ff7 libicucore.A.dylib ??? (???)
<18098dcf431603fe47ee027a60006c85> /usr/lib/libicucore.A.dylib
0x96de4000 - 0x96fb2ff3 com.apple.security 5.0.4 (34102)
<55dda7486df4e8e1d61505be16f83a1c> /System/Library/Frameworks/
Security.framework/Versions/A/Security
0x97043000 - 0x97047fff libmathCommon.A.dylib ??? (???) /usr/lib/
system/libmathCommon.A.dylib
0x97048000 - 0x970c7ff5 com.apple.SearchKit 1.2.1 (1.2.1)
<3140a605db2abf56b237fa156a08b28b> /System/Library/Frameworks/
CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/
Versions/A/SearchKit
0x970c8000 - 0x970d3fe7 libCSync.A.dylib ??? (???)
<e6aceed359bd228f42bc1246af5919c9> /System/Library/Frameworks/
CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x970d4000 - 0x970e2ffd libz.1.dylib ??? (???)
<5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0xba900000 - 0xba916fff libJapaneseConverter.dylib ??? (???)
<7b0248c392848338f5d6ed093313eeef> /System/Library/CoreServices/
Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21fe2 libKoreanConverter.dylib ??? (???)
<51586b8d9ef39123fbe6918f12d8285f> /System/Library/CoreServices/
Encodings/libKoreanConverter.dylib
0xfffe8000 - 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/
libobjc.A.dylib
0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/
libSystem.B.dylib
Cheers,
John
On Jan 4, 2009, at 7:39 AM, Martin Dobias wrote:
> Hi all
> today I've decided to make a first public release of symbology-ng
> plugin which is meant as a prototype for new generation symbology for
> vector layer. I've chosen python because of faster development and
> ability to deploy it more easily to potential testers. Later, I'd like
> to integrate it to QGIS and deprecate the original rendering code. You
> can install the plugin from my sandbox:
> http://mapserver.sk/~wonder/qgis/plugins-sandbox.xml
> What are the main highlights:
> - compose symbols from one or more symbol layers
> - load and store symbols (and other items) from/to a "style" file
> - override order in which symbol layers are drawn for high-quality
> output (done in multiple rendering passes)
> - color ramps (gradient or random colors from some part of color
> space)
> - use custom symbols and color ramps when generating categories for
> a renderer
> - new symbol types, e.g. marker line - polyline composed from markers
> - lock symbol layer's color so it doesn't get changed when applying
> color on the whole symbol
> - modual architecture for symbol layers
> When you load the plugin, you'll get two new buttons in a toolbar:
> 1. one that opens a new window with currently selected vector layer
> rendered in it (with current extent). in that window you can also
> change renderer and symbology settings (although graduated symbol
> renderer is missing GUI so far and categorized symbol renderer only
> allows you to add all categories)
> 2. the other button opens style manager
> The rendering is slower than with current rendering in QGIS, but
> that's caused by the dynamic nature of the language and missing
> optimizations. There are some features which are not yet available in
> GUI. There are also some missing features, see TODO file.
> I would be glad to hear some feedback from you!
> Martin
> Qgis-developer mailing list
