[Qgis-developer] [Plugin] Added, deleted or changed features in a layer
Martin Dobias wonder.sk at gmail.com
Tue Jan 13 18:01:58 EST 2009
Hi Olivier
On Sun, Jan 11, 2009 at 5:39 PM, Olivier Tournaire <olitour at gmail.com> wrote:
>> Also dont forget the new methods should be added to the corresponding
>> sip file so that they appear in python bindings!
> OK. Is there only one file to change python/core/sipcoreQgsVectorLayer.cpp ?
no, that's only a generated file. You'll need to modify
python/core/qgsvectorlayer.sip. Usually one needs to only copy the
definitions from .h file to appropriate .sip without more changes. If
you need some more help, just ask...
Bye
Martin
