[Qgis-developer] Deploying Python Plugins that require PostgreSQL
drivers
Andreas Neumann
a.neumann at carto.net
Mon Jan 26 15:33:14 EST 2009
yes - I am talking about python only plugins. No C++ involved.
here ist my python plugin source:
http://www.carto.net/neumann/temp/usterfinder.zip
Thanks again,
Andreas
William Kyngesburye wrote:
> No, binary/source of your plugin. I have the Qt stuff.
> Or maybe I misunderstood your plugin - did you try a C++ version? Or
> is it only python? Maybe that is the problem, the Qt SQL plugins,
> when bundled in Qgis, would be seen by the Qgis binary and any C++
> plugins, but maybe the bundled PyQt can't see those. Maybe it works
> when the Qt SDK is installed because PyQt looks in the default Qt
> plugin folder (even though Qgis looks in the Qgis app bundle).
> Tom - do you know if PyQt uses the same qt.conf in the Qgis bundle
> that Qgis itself uses? Or is there a way in Python to set the plugin
> paths?
> On Jan 26, 2009, at 2:06 PM, Andreas Neumann wrote:
Andreas Neumann
Böschacherstrasse 6
CH-8624 Grüt (Gossau ZH)
Switzerland
Phone: ++41-44-2736668
Email: a.neumann at carto.net
Web: http://www.carto.net/neumann/
SVG Examples: http://www.carto.net/papers/svg/samples/
SVG.Open: http://www.svgopen.org/
