[Qgis-developer] Re: [Qgis-user] Graticules
Tim Sutton
tim at linfiniti.com
Fri Jan 30 16:45:48 EST 2009
Hi
Best to ask this on the mailing list...
Regards
Tim
On Thu, 2009-01-29 at 17:38 -0200, Maurício de Paulo wrote:
> Following this idea, would carson be interested in including
> FindByAttribute together with his tools as he already have a select by
> location that is a sister tool. At least the menu bar will be more
> organised. I could also put FindByAttribute in the same menu (inside
> Tools-> Sampling Tools). Is it a good idea?
> Maurício de Paulo
> On Tue, Jan 27, 2009 at 8:05 AM, Tim Sutton <tim at linfiniti.com> wrote:
> Hi
> I suggest we remove my original C++ graticule plugin from svn
> since
> Carson's tools collection now replicates this.
> Any objections?
> Regards
> Tim
> On Tue, 2009-01-27 at 08:56 +0100, Agustin Lobo wrote:
> > Carson,
> > This is actually almost perfect and I do confirm that works
> > in the projection being defined for the project.
> > The only improvement would be that once you select "Input
> Boundary
> > Layer" you should get the actual values written in the X,Y
> fields
> > of "Input Coordinates". In this way, the user could then
> select "Input
> > coordinates" to slightly modify the values (you normally
> want
> > the grid at rounded positions).
> > Thanks a lot
> > Agus
> > Carson Farmer wrote:
> > > Hi Augus
> > >> Agustin Lobo wrote:
> > >>>> Could be considered that the graticule creator work in
> projected
> > >>>> coordinates? It's hard making a UTM graticule by
> entering geographic
> > >>>> values. Also, it would useful if the default values for
> the extent
> > >>>> could be those of the displayed region and/or those of
> the extent of
> > >>>> a given layer.
> > > You could probably do this with the vector grid function
> in fTools as
> > > well...
> > > Though now that I think of it... you might be limited to
> geographic
> > > coordinates here as well... but you could probably get
> around this by
> > > specifying UTM coordinates, and defining the projection to
> be UTM after
> > > the grid is created... I'm not sure though...
> > > C
> > >> Tim Sutton wrote:
> > >>> On my last round of edits to the graticule plugin, I put
> in
> > >>> the groundwork for this. I will add it to the feature
> plan for 1.1
> > >> Hi,
> > >> if you use the GRASS plugin you can theoretically do such
> things with the
> > >> v.mkgrid module.
> > >> perhaps src/plugins/grass/modules/v.mkgrid.region.qgm
> needs to be updated
> > >> to give access to more module options:
> http://grass.osgeo.org/grass64/manuals/html64_user/v.mkgrid.html
> > >> maybe as a new v.mkgrid.coor.qgm ?
> > >> Hamish
> > >> _______________________________________________
> > >> Qgis-user mailing list
> > >> Qgis-user at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Tim Sutton - QGIS Project Steering Committee Member (Release
> Manager)
> Visit http://linfiniti.com to find out about:
> * QGIS programming services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting & Support Services
> Skype: timlinux Irc: timlinux on #qgis at freenode.net
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090130/bd86fa07/attachment.bin
