[Qgis-developer] trac error
Giovanni Manghi
giovanni.manghi at gmail.com
Thu Jul 2 05:47:21 EDT 2009
Hi all,
I'm trying to open a ticket in the qgis trac but what I get is
Oops…
Trac detected an internal error:
If you think this really should work and you can reproduce it, you
should consider reporting this problem to the Trac team.
Go to http://trac.edgewall.org/ and create a new ticket where you
describe the problem, how to reproduce it. Don't forget to include the
Python traceback found below.
TracGuide — The Trac User and Administration Guide
Python Traceback
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 387, in dispatch_request
dispatcher.dispatch(req)
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 237, in dispatch
resp = chosen_handler.process_request(req)
File "/usr/lib/python2.3/site-packages/trac/ticket/web_ui.py", line 129, in process_request
ticket = Ticket(self.env, db=db)
File "/usr/lib/python2.3/site-packages/trac/ticket/model.py", line 37, in __init__
self.fields = TicketSystem(self.env).get_ticket_fields()
File "/usr/lib/python2.3/site-packages/trac/ticket/api.py", line 123, in get_ticket_fields
options = [val.name for val in cls.select(self.env, db=db)]
File "/usr/lib/python2.3/site-packages/trac/ticket/model.py", line 418, in select
(cls.type,))
File "/usr/lib/python2.3/site-packages/trac/db/util.py", line 50, in execute
return self.cursor.execute(sql_escape_percent(sql), args)
DataError: invalid input syntax for integer: "4.0"
-- Giovanni --
