[Qgis-developer] QgsVertexMarker modified class: Plot moving
	points over a map at fixed rate
    Luca Pascale
    pascale.luca.it at gmail.com
    Thu Jul  2 08:59:39 EDT 2009
Hi Martin,
I solve the problem of pixmap visualization using the correct icon dimension
(setIconSize () )
but I don' t understand how to use boundingRect() and... which
boundingRect() method----
Luca
2009/7/2 Martin Dobias <wonder.sk at gmail.com>
> On Thu, Jul 2, 2009 at 11:43 AM, Luca Pascale<pascale.luca.it at gmail.com>
> wrote:
> >     case ICON_CUSTOM:
> >       QPixmap pixmap(QSize(22,22));
> >       pixmap.load(mFileName);
> >       p->drawPixmap(0,0,pixmap);
> >       break;
> It would be wiser to load the pixmap just once and keep the QPixmap,
> it will save some time when doing updates. Additionally, you don't
> have to set pixmap's size before the load() method - the pixmap will
> be resized to the required size during the load.
> > The problem now is that the icon (png file) is not plotted correctly
> until I
> > refresh the map canvas.
> > See the attached images.
> > notcorrectvisualization.png is what I obtain on the screen
> > and
> > correctvisualization.png is waht I obtain after pushed the refresh
> button.
> > Any suggestion to solve ??
> Yes: you have to update boundingRect() function to return correct
> rectangle of the marker. Currently for markers it's something like
> (-5,-5)..(5,5) while you probably want a bounding rect e.g.
> (0,0)..(22,22). But think also where dou you actually want to put the
> pixmap - currently you draw it in a way that the position is at the
> upper left corner of the pixmap. Maybe you want it to be in the
> center...?
> Martin
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090702/7dcb504c/attachment.html
