[QGIS-Developer] Build QGIS on Windows - Query
Abhay
abhay.menon at gmail.com
Thu Jul 9 15:18:26 EDT 2009
On Fri, Jul 10, 2009 at 12:21 AM, godofredo contreras <frdcn at hotmail.com>wrote:
> Hello Abhay:
> The uptodate documentation for building is in a file named INSTALL. You can
> find this file
> in the directory where you checked out the qgis sources.
> Regards
> Godofredo Contreras
> From: abhay.menon at gmail.com
> Date: Thu, 9 Jul 2009 22:19:09 +0530
> Subject: [QGIS-Developer] Build QGIS on Windows - Query
> To: qgis-developer at lists.osgeo.org
> Hello List,
> I am following the build procedure qgis on windows using the method / step
> defined as per Building From Source [1] on wiki.
> The file qgis_msvc_deps_except_qt4.zip[2] seem to be missing or
> un-reachable.
> Could anyone let me know if the file is available in some other link.
> Rgds.
> Abhay.
> [1]
> http://wiki.qgis.org/qgiswiki/BuildingFromSource#head-ef5d12db147835afba491f69e168b6033a4f12a2
> [2] http://qgis.org/uploadfiles/msvc/qgis_msvc_deps_except_qt4.zip
> Windows Live™: Keep your life in sync. Check it out.<http://windowslive.com/explore?ocid=TXT_TAGLM_WL_BR_life_in_synch_062009>
Hi Godofredo,
Thanks for the quick response but the INSTALL also providing the same link
for qgis_msvc_deps_except_qt4.zip
this link is providing the following error.
<Quote>
404 - Component not found
You may not be able to visit this page because of:
1) an out-of-date bookmark/favourite
2) a search engine that has an out-of-date listing for this site
3) a mistyped address
4) you have no access to this page
5) The requested resource was not found.
6) An error has occurred while processing your request.
Please try one of the following pages:
Home Page
If difficulties persist, please contact the System Administrator of this
site.
Component not found
</Quote>
Has the instruction of the Build Document changed or been updated (section
8) ??
Rgds.
Abhay.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090710/af85d4dd/attachment.html
