[QGIS-Developer] Build QGIS on Windows - Query
godofredo contreras frdcn at hotmail.com
Thu Jul 9 15:48:14 EDT 2009
Reading the INSTALL file I can see it is also outdated.
The file qgis_msvc_deps_except_qt4.zip used to contain all headers and libraries needed to build Qgis, now you can download OSGeo4W from here: http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe and download and install GDAL, GEOS, GSL, EXPAT, POSTGRES libs.
then in the cmake step point to lib and include folders of your osgeo4w installation directory, this way cmake can find the dependencies.
Regards
Godofredo Contreras
Date: Fri, 10 Jul 2009 00:48:26 +0530
Subject: Re: [QGIS-Developer] Build QGIS on Windows - Query
To: frdcn at hotmail.com
CC: qgis-developer at lists.osgeo.org
On Fri, Jul 10, 2009 at 12:21 AM, godofredo contreras <frdcn at hotmail.com> wrote:
Hello Abhay:
The uptodate documentation for building is in a file named INSTALL. You can find this file
in the directory where you checked out the qgis sources.
Regards
Godofredo Contreras
Date: Thu, 9 Jul 2009 22:19:09 +0530
Subject: [QGIS-Developer] Build QGIS on Windows - Query
To: qgis-developer at lists.osgeo.org
Hello List,
I am following the build procedure qgis on windows using the method / step defined as per Building From Source [1] on wiki.
The file qgis_msvc_deps_except_qt4.zip[2] seem to be missing or un-reachable.
Could anyone let me know if the file is available in some other link.
Rgds.
Abhay.
[1] http://wiki.qgis.org/qgiswiki/BuildingFromSource#head-ef5d12db147835afba491f69e168b6033a4f12a2
[2] http://qgis.org/uploadfiles/msvc/qgis_msvc_deps_except_qt4.zip
Windows Live™: Keep your life in sync. Check it out.
Hi Godofredo,
Thanks for the quick response but the INSTALL also providing the same link for qgis_msvc_deps_except_qt4.zip
this link is providing the following error.
<Quote>
404 - Component not found
You may not be able to visit this page because of:
1) an out-of-date bookmark/favourite
2) a search engine that has an out-of-date listing for this site
3) a mistyped address
4) you have no access to this page
5) The requested resource was not found.
6) An error has occurred while processing your request.
Please try one of the following pages:
Home Page
If difficulties persist, please contact the System Administrator of this site.
Component not found
</Quote>
Has the instruction of the Build Document changed or been updated (section 8) ??
Rgds.
Abhay.
_________________________________________________________________
http://windowslive.com/explore?ocid=TXT_TAGLM_WL_BR_life_in_synch_062009
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090709/463496f2/attachment-0001.html
