[QGIS-Developer] Build QGIS on Windows - Query
Abhay abhay.menon at gmail.com
Fri Jul 10 13:23:13 EDT 2009
On Fri, Jul 10, 2009 at 1:18 AM, godofredo contreras <frdcn at hotmail.com>wrote:
> Reading the INSTALL file I can see it is also outdated.
> The file qgis_msvc_deps_except_qt4.zip used to contain all headers and
> libraries needed to build Qgis, now you can download OSGeo4W from here:
> http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe and download and
> install GDAL, GEOS, GSL, EXPAT, POSTGRES libs.
> then in the cmake step point to lib and include folders of your osgeo4w
> installation directory, this way cmake can find the dependencies.
> Regards
> Godofredo Contreras
Thanks Godofredo and Tim for your inputs.
I am able to compile the missing dependency like sqlite and postgresql using
the OSGeo4W libs.
The only question I am left with is, I have installed pre-compiled version
of QGis that come with OSGeo4W.
The plugins dir of those present in my home dir under *".qgis"* folder is
raising error related to python plugin.
Is there a possibility to be able to run my source compiled edition with
separate profile?
Thanks and Rgds.
Abhay.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090710/38a2d3c4/attachment.html
