[Qgis-developer] PyQt4/Qwt5 errors
Jürgen E. Fischer jef at norbit.de
Tue Jul 21 17:05:44 EDT 2009
Hi Paolo,
On Tue, 21. Jul 2009 at 21:03:14 +0200, Paolo Cavallini wrote:
> Jürgen E. Fischer ha scritto:
> > Seems unrelated to QGIS.  Looks like your qwt bindings don't match your qwt
> > libraries.
> upgraded to python-qwt5-qt4 (5.1.1~cvs20090626+dfsg-2) as per debian
> unstable, and recopiled qgis: now it segfaults on startup, nice result. ;)
> Probably python-qwt5-qt4 and libqwt5-qt4 (5.2.0-1) are not aligned in
> Debian.
Recompiling itself qgis shouldn't change a thing.  qgis doesn't know anything
about qwt.  The upgrade was probably enough.
> >> libraries.
> even reverting to an earlier version and recompiling now I cannot start
> qgis (even removing pyplugins). It crashes on "Starting python".
> Removing all qwt5 stuff does not help, nor recompiling afterwards, so
> I'm basicaly stuck: any suggestion?
Hm, doesn't even seem to be a (generic) debian problem.  profiletool loads fine
using a build of r11106 on unstable/amd64.
$ COLUMNS=130 dpkg -l qgis python-qgis python-qgis-common python-qwt5-qt4 libqwt5-qt4 libqt4-{gui,core} python-qt4
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err: uppercase=bad)
||/ Name                       Version                    Description
ii  libqt4-core                4:4.5.2-1                  transitional package for Qt 4 core non-GUI runtime libraries
ii  libqt4-gui                 4:4.5.2-1                  transitional package for Qt 4 GUI runtime libraries
ii  libqwt5-qt4                5.2.0-1                    Qt4 widgets library for technical applications (runtime)
ii  python-qgis                1.2.0                      Python bindings to Quantum GIS
ii  python-qgis-common         1.2.0                      Python bindings to Quantum GIS - architecture-independent files
ii  python-qt4                 4.5.1-1                    Python bindings for Qt4
ii  python-qwt5-qt4            5.1.1~cvs20090626+dfsg-2   Python version of the Qwt5 technical widget library
ii  qgis                       1.2.0                      Geographic Information System (GIS)
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
