[Qgis-developer] edting non active qgis/grass layers
Giovanni Manghi
giovanni.manghi at gmail.com
Mon Jul 27 07:48:07 EDT 2009
> GRASS "layers" in a GRASS "vector map" have *common geometry*. You can't
> edit the geometry of one GRASS "layer" not interfering with the
> geometry of the other "layer" in a single "vector map".
> This is different than in case of e.g. shapefiles, where each layer is a
> set of files dedicated only to a particular layer, thus when you edit
> it, you do so only for this particular layer.
> GRASS "layers" and OGR "layers" are different things.
I understand (I already knew what was the difference), but that wasn't
my point.
-- Giovanni --
