[Qgis-developer] grass modules
Lami Gis3w
lami at gis3w.it
Tue Jul 28 02:12:27 EDT 2009
Hi all,
with the new v.out.ogr and the new r.out.gdal you can export to all
formats supported by GDAL/OGR library (GML and other formats with the
same problem) but you have to specify the right extension in the output
file name. Of course I can specify this in the module.
The alternative is to create a modules for every format supported by
GDAL/OGR with an increase of the modules in the GRASS tools menu.
Any advices for the other developers?
Thank you very much
Leonardo
Paolo Cavallini ha scritto:
> Hi all.
> Some grass modules seem redundant, with caveats:
> - v.out.ogr.gml and the generic v.out.ogr
> The generic one does not seem to work for GML:
> v.out.ogr input=test at user1 type=area layer=1 format=GML dsn=/home/paolo/Desktop
> olayer=prova2 -e -c
> ERROR 4: Failed to create GML file /home/paolo/Desktop.
> Unable to open OGR data source '/home/paolo/Desktop'
> whereas v.out.ogr.gml works, apparently because it allows to define the layer name
> - v.out.ogr.mapinfo and the generic v.out.ogr
> I think the generic one is more than enough for mapinfo; I suggest to remove the
> specific one (that has also a wrong description)
> - r.out.gdal.gtiff and v.out.ogr
> the only difference is that the gtiff module automatically writes the file
> extension (.tif), whereas the generic one writes a file without extension, which
> can e confusing and annoying. I would suggest to remove the specific one if the
> generic can cope with this.
> All the best.
Leonardo Lami
Gis3W
Tel. +39 349 1310164
E-mail: lami at gis3w.it
Web: www.gis3w.it
Via Colombo, 3 - 51010 Massa e Cozzile (PT)
