[Qgis-developer] eVis tests
Peter Ersts
ersts at amnh.org
Mon Jul 27 11:46:13 EDT 2009
Paolo,
It has been fixed in r11184. eVis actually just uses the delimited text
provider ( needs to be updated to use a different provider someday ) and
there was a problem with the uri format that was introduced when
preparing for migration to the QGIS trunk.
let me know if you have any other problems.
-pete
Paolo Cavallini wrote:
> Hi all.
> Running the eVis tutorial
> http://biodiversityinformatics.amnh.org/index.php?section_id=116
> goes smoothly, but when I try to run a query (either by hand or with a preset
> query from xml), I get a popup with layer name, x and y (I add a name, select x
> and y fields), then:
> The layer is not a valid layer and can not be added to the map
> The connection seems to be ok:
> New Database connection requested...
> Connection to [./home/paolo/Desktop/eVis_tutorial/PhotoPoints.db] established
> Tables:
> ->Points
> ->Attributes
> Any explanation? QGIS from trunk on debian unstable.
> All the best.
Peter J. Ersts, Software Developer
American Museum of Natural History
Center for Biodiversity and Conservation
Central Park West at 79th Street
New York, New York 10024
Web: http://biodiversityinformatics.amnh.org
Web: http://cbc.amnh.org
Open Source,
...evolving through community cooperation to change the world bit by bit
Quantum GIS Raster Development Team.
