[Qgis-developer] eVis tests
Paolo Cavallini cavallini at faunalia.it
Mon Jul 27 12:59:29 EDT 2009
Peter Ersts ha scritto:
> It has been fixed in r11184. eVis actually just uses the delimited text
> provider ( needs to be updated to use a different provider someday ) and
> there was a problem with the uri format that was introduced when
> preparing for migration to the QGIS trunk.
> let me know if you have any other problems.
ok, now it works - the only problem is that the path stored in the sqlite db is
a windows one. Perhaps it would be good to have two versions of the tutorial
(ie, of the xml query and the db)?
All the best, and many thanks.
Paolo Cavallini: http://www.faunalia.it/pc
