[Qgis-developer] Bug in Attribute Table for Postgis Data Sources
Andreas Neumann a.neumann at carto.net
Tue Jun 2 11:22:16 EDT 2009
Hi Jürgen,
I can confirm that it works fine now!
Thank you very much - this was a really quick fix!!
Andreas
On Tue, June 2, 2009 4:41 pm, Jürgen E. Fischer wrote:
> Hi Andreas,
> On Tue, 02. Jun 2009 at 15:56:46 +0200, Andreas Neumann wrote:
>> yes - this seems to be the case. The geometry column is the problem. It
>> works fine for tables where the geometry column is at the end but fails
>> for tables where the geometry_column is at the beginning.
>> Should I file a bug on this?
> No, should be fixed in r10875.
>> I consider this a major bug that should also be backported to the 1.1
>> release. I think this wasn't a problem in the 1.0 release, since this
>> had
>> a different table implementation - am I right?
> We only backport fixes to 1.0, but that's not necessary here as the 1.0
> implementation doesn't have that problem - as you already noted.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel.
> +49-4931-918175-20
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
> +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
