[Qgis-developer] Bug in Attribute Table for Postgis Data Sources
Jürgen E. Fischer
jef at norbit.de
Tue Jun 2 10:41:31 EDT 2009
Hi Andreas,
On Tue, 02. Jun 2009 at 15:56:46 +0200, Andreas Neumann wrote:
> yes - this seems to be the case. The geometry column is the problem. It
> works fine for tables where the geometry column is at the end but fails
> for tables where the geometry_column is at the beginning.
> Should I file a bug on this?
No, should be fixed in r10875.
> I consider this a major bug that should also be backported to the 1.1
> release. I think this wasn't a problem in the 1.0 release, since this had
> a different table implementation - am I right?
We only backport fixes to 1.0, but that's not necessary here as the 1.0
implementation doesn't have that problem - as you already noted.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
