[Qgis-developer] New GeoCoding python plugin
Giovanni Manghi
giovanni.manghi at gmail.com
Wed Jun 3 13:46:18 EDT 2009
Works for me on Ubuntu 8.10.
I had to install manually simplejson and this version
http://code.google.com/p/geopy/wiki/ReverseGeocoding
of geopy.
Thanks a lot!
-- Giovanni --
On Wed, 2009-06-03 at 19:24 +0200, Alessandro Pasotti wrote:
> Hello,
> I wrote a new GeoCoding python plugin that uses Google webservices,
> this plugin is completely independent from the existing geocoding
> plugin written by perrygeo (no shared code).
> The plugin supports geocoding and reverse geocoding.
> The plugin has an external dependency on geopy so I decided to include
> it in the zip.
> geopy has a dependency on simplejson (which has some C code, so I
> did'nt include it in the zip).
> I tested it locally but Paolo Cavallini reported a problem (which I
> wasn't able to reproduce) with geopy dependency.
> I would really appreciate you comments, impressions and any help in
> fixing the a.m. issue if you experience it.
> The plugin is available at this repo:
> http://elpaso.homelinux.org/qgis/plugins.xml
> Thank you in advance!
> Alessandro Pasotti
> w3: www.itopen.it
> Qgis-developer mailing list
