[Qgis-developer] New GeoCoding python plugin
kimaidou
kimaidou at gmail.com
Fri Jun 5 08:33:49 EDT 2009
Hi
I am under ubuntu 9.04, Qgis 1.0.1
I have installed geopy, using this
svn checkout http://geopy.googlecode.com/svn/branches/reverse-geocode geopy
cd geopy/
sudo python setup.py install
I worked, see:
Installed /usr/local/lib/python2.6/dist-packages/geopy-0.93dev_r84-py2.6.egg
Processing dependencies for geopy==0.93dev-r84
Finished processing dependencies for geopy==0.93dev-r84
But the plugin stills complains about geopy missing. I have not installed it
with easy_install, because I do not know what it is (and installing the
package python-virtualenv did not help :( )
Any hints ?
Thanks in advance
kimaidou
2009/6/3 Giovanni Manghi <giovanni.manghi at gmail.com>
> Works for me on Ubuntu 8.10.
> I had to install manually simplejson and this version
> http://code.google.com/p/geopy/wiki/ReverseGeocoding
> of geopy.
> Thanks a lot!
> -- Giovanni --
> On Wed, 2009-06-03 at 19:24 +0200, Alessandro Pasotti wrote:
> > Hello,
> > I wrote a new GeoCoding python plugin that uses Google webservices,
> > this plugin is completely independent from the existing geocoding
> > plugin written by perrygeo (no shared code).
> > The plugin supports geocoding and reverse geocoding.
> > The plugin has an external dependency on geopy so I decided to include
> > it in the zip.
> > geopy has a dependency on simplejson (which has some C code, so I
> > did'nt include it in the zip).
> > I tested it locally but Paolo Cavallini reported a problem (which I
> > wasn't able to reproduce) with geopy dependency.
> > I would really appreciate you comments, impressions and any help in
> > fixing the a.m. issue if you experience it.
> > The plugin is available at this repo:
> > http://elpaso.homelinux.org/qgis/plugins.xml
> > Thank you in advance!
> > Alessandro Pasotti
> > w3: www.itopen.it
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090605/371420c6/attachment.html
