[Qgis-developer] QgsProjectionSelector in Plugin?
Florian Hillen
fhillen at uni-osnabrueck.de
Fri Mar 6 18:16:27 EST 2009
Hi Tim,
thanks for that, it helps a lot and it saves a lot of work for me ;)
Best regards,
Florian
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Florian
> Florian Hillen wrote:
>> Hi,
>> is it possible to include the QgsProjectionSelector in my plugin?
>> I define this class in Qt Designer, but if I make the project, I recieve
>> the following error:
>> In file included from
>> C:/dev/cpp/qgis/build/src/plugins/test/ui_gdalguibase.h:26
>> from C:\dev\cpp\qgis\src\plugins\test\/gdalgui.h:17,
>> from C:\dev\cpp\qgis\src\plugins\test\plugin.cpp:27:
>> C:/dev/cpp/qgis/src/plugins/test/../../gui/qgsprojectionselector.h:14:42:
>> ui_qgs
>> projectionselectorbase.h: No such file or directory
>> So the header can't find the ui anymore. Can I fix that or isn't it
>> possible to use qgis-gui-parts in plugins?
> Indeed it is possible. You should use QgsGenericProjectionSelector since
> it was designed to be used with your own custom messages etc.
> #include <qgsgenericprojectionselector.h>
> void CoordinateCapture::setCRS()
> QgsGenericProjectionSelector mySelector( mQGisIface->mainWindow() );
> mySelector.setSelectedCrsId( mCrs.srsid() );
> if ( mySelector.exec() )
> mCrs.createFromSrsId( mySelector.selectedCrsId() );
> mTransform.setDestCRS( mCrs );
> mUserCrsDisplayPrecision = ( mCrs.mapUnits() == QGis::Degrees ) ? 8
> : 3; //precision depends on CRS units
> See the src/plugins/coordinatecapture.cpp sources for more details.
> Hope that helps!
> Regards
> Tim
>> Best regards,
>> Florian
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAkmxhb4ACgkQqk07qZdiYje+qgCgpl4glbaJZfnGZ/npMq7oD4mv
> G2sAn0t2SllnicEAQcLAfIJRnmfujsLf
> =uXN/
> -----END PGP SIGNATURE-----
