[Qgis-developer] QgsProjectionSelector in Plugin?
Florian Hillen
fhillen at uni-osnabrueck.de
Fri Mar 6 13:18:31 EST 2009
is it possible to include the QgsProjectionSelector in my plugin?
I define this class in Qt Designer, but if I make the project, I recieve
the following error:
In file included from
C:/dev/cpp/qgis/build/src/plugins/test/ui_gdalguibase.h:26
from C:\dev\cpp\qgis\src\plugins\test\/gdalgui.h:17,
from C:\dev\cpp\qgis\src\plugins\test\plugin.cpp:27:
C:/dev/cpp/qgis/src/plugins/test/../../gui/qgsprojectionselector.h:14:42:
ui_qgs
projectionselectorbase.h: No such file or directory
So the header can't find the ui anymore. Can I fix that or isn't it
possible to use qgis-gui-parts in plugins?
Best regards,
Florian
