[Qgis-developer] Map composer legend item transparency
John C. Tull jctull at gmail.com
Sun Mar 15 20:05:01 EDT 2009
I saw some maps recently, presumably from ArcGIS, that had the vector
transparency with a tiny sample of the underlying hillshade beneath.
This would handle your concern for drapes, but would not account for
multiple vector overlays. I think just having the vector transparency
alone would be an improvement.
John
On Mar 13, 2009, at 3:59 PM, Andreas Neumann wrote:
> yes, I had a similar issue with some of my projects. But I don't
> know if it is very easy to solve? Potentially, there could be many
> layers with different transparency settings interacting with each
> other. Think of a transparent layer on a transparent layer on a
> transparent layer on a hillshade ... What should the legend do in
> this case?
> It is definitely worth some thinking of course, since it is a real
> problem in the legend ... How do other GIS solve the problem?
> Andreas
> John C. Tull wrote:
>> Marco,
>> Is there a possibility to have the composer legend show vectors
>> layers with the level of transparency in the map canvas. For
>> instance, I have a land ownership layer that I drape over a
>> hillshade. I set this layer to 50% transparency, but the map legend
>> shows them at 100%. The colors can look quite different in the map
>> and the legend as a consequence.
>> Hopefully this is doable. I think it would be a good improvement.
>> I'll throw it in trac if you need, but will await your response
>> first.
>> Cheers,
>> John
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
