[Qgis-developer] Map composer legend item transparency
Andreas Neumann
a.neumann at carto.net
Fri Mar 13 18:59:55 EDT 2009
yes, I had a similar issue with some of my projects. But I don't know if
it is very easy to solve? Potentially, there could be many layers with
different transparency settings interacting with each other. Think of a
transparent layer on a transparent layer on a transparent layer on a
hillshade ... What should the legend do in this case?
It is definitely worth some thinking of course, since it is a real
problem in the legend ... How do other GIS solve the problem?
Andreas
John C. Tull wrote:
> Marco,
> Is there a possibility to have the composer legend show vectors layers
> with the level of transparency in the map canvas. For instance, I have
> a land ownership layer that I drape over a hillshade. I set this layer
> to 50% transparency, but the map legend shows them at 100%. The colors
> can look quite different in the map and the legend as a consequence.
> Hopefully this is doable. I think it would be a good improvement. I'll
> throw it in trac if you need, but will await your response first.
> Cheers,
> John
> Qgis-developer mailing list
