[Qgis-developer] qgis 1.0.0 mingw release
Volkan Kepoglu
vkepoglu at gmail.com
Sat Mar 21 05:19:13 EDT 2009
by the way, i forget to mention that the file qtcore4.dll is not exist.
On Sat, Mar 21, 2009 at 11:15 AM, Volkan Kepoglu <vkepoglu at gmail.com> wrote:
> i did 3 attempts, but none of them has worked.
> 1. directly installed to win xp professional service pack 3 and gives
> following error:
> qgis.exe - Unable To Locate Component
> This application has failed to start because QtCore4.dll was not found.
> Re-installing the application may fix this problem.
> 2. as virtual os with virtual box. guest: win xp sp3, host: win vista home
> premium sp1
> clean operation system. qgis not installed previously, but the same error.
> 3. directly in win vista home premium sp1
> the same error.
> i had some free time. :-)
> i hope this will help.
> On Sat, Mar 21, 2009 at 2:20 AM, pasquale <pa.casciano at alice.it> wrote:
>> hi. I have created a qgis 1.0.0 mingw release.
>> Based on these instructions:
>> http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html
>> with newer versions requirements:
>> qt 4.4.3
>> sip 4.7.9
>> pyqt 4.4.4
>> etc..
>> Here's the package:
>> http://uploading.com/files/R57NTDPH/QGIS-1.0.0-Setup.exe.html
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Regards,
Volkan Osman Kepoglu
PhD Candidate
GGIT Department in METU,
Ankara, Turkey.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090321/af8a0324/attachment.html
