[Qgis-developer] Problem compiling with SpatiaLite support
Andreas Neumann a.neumann at carto.net
Thu Mar 26 16:54:19 EDT 2009
this would be cool.
I have hopes that SpatiaLite will be a shapefile replacer, if it will be
supported by more GIS projects/products. Other people want to see ESRI's
file geodatabase as a replacement, but the Filegeodatabase is more
complex to handle and corrupted with vendor-specific data.
So a good support for SpatiaLite has some potential to replace the
ageing shapefile format ...
Andreas
Tim Sutton wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi
> Alessandro Furieri wrote:
>> Andreas Neumann ha scritto:
>>> Hi,
>>> I was trying to compile with SpatiaLite support enabled, however, I am
>>> running into an error:
>> Hi Andreas,
>> your problem is exactly the same noticed
>> by William Kyngesburye [using v.2.2 headers]
>> very quick fix: in 'qgsspatialiteprovider.h' add:
>> #include <stdio.h>
>> immediately before:
>> #include <spatialite/gaiageo.h>
>> even better: use the latest SpatiaLite v.2.3
>> http://www.gaia-gis.it/spatialite-2.3/
>> bye,
>> Sandro
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Does spatial lite provide all the same features of sqlite3 with spatial
> extensions added? Is there an amalgamated (all sources in a single file)
> version of spatial lite as there is for sqlite? If there is can I
> suggest that we replace the amalgamated sqlite3 sources I put into QGIS
> sources some time ago with the spatialite amalgamated sources and change
> cmake to always use the internal copy of spatiallite?
> Regards
